Configuring a Redirect Allowlist
To avoid redirect vulnerabilities in the Directory Server STS, Laserfiche Directory Server administrators can enable checking against an allowlist that restricts redirects to approved domains.
- On the computer hosting the Directory Server Security Token Service (STS), open the STS configuration site, by default, the address is: https://localhost/LFDSSTS/configuration.
- To set a list of allowed domains, select the Allow additional domains to redirect option.
Note: If you turn on Allow additional do mains to redirect, but do not specify any values in the Additional allowlist domains, only the domain the STS resides on will be allowed.
- In the Additional allowlist domains textbox, add the desired domains, separating domain names with a comma. The specified domains should match the values used by users to access the respective Laserfiche application. For example, if users browse to Laserfiche Forms using https://sampledomain.com/forms, and the Directory Server STS does not reside on sampledomain.com, then you should append sampledomain.com to the list.
- Select Update to save your changes.
Note: To configure STS sites for your SAML identity providers, navigate to STS Sites.
