Managing Organizations
On the Accounts page in Laserfiche Directory Server, the Organizations tab allows you to view and create organizations. Organizations let you assign rights to specific groups of people. You can grant registered users the ability to configure settings for the organization.
Click + Organizations to create an organization in Directory Server. Organizations support a hierarchical structure; you can create sub-organizations under a parent organization.
The Generate usage report button saves a comma-separated (CSV) file with an overview of allocated licenses for the Directory Server site.
Organization members and settings
Select an organization from the list to view additional properties about the organization.
  • In the Members tab, you can:
    • View a list of current members.
    • Add new members with the + Add button. This brings up a dialog box where you can search for existing Directory Server users and add them to the organization.
  • In the Security tab, you can assign rights to users or groups.
    • Select Show service users to view and assign rights to the accounts that Laserfiche applications use to connect to Directory Server.
  • In the Settings tab, select the email server profile and email template for password reset emails for members of the organization.
