Error Codes Reference
Error Code | Message | Notes |
0 | An unknown error has occurred. | |
1 | Database management system is unknown or unsupported. | |
2 | Database not found. | |
3 | Object already exists. | |
4 | The product is not licensed. | |
5 | The license format is not supported. | |
6 | Invalid fingerprint. | |
7 | Host not found. | |
8 | Invalid primary license. | |
9 | Application not found. | |
10 | Container not found. | |
12 | User not found. | |
13 | Group not found. | |
14 | Organization not found. | |
15 | Identity provider not found. | |
16 | Invalid user name or password. | |
17 | The current session is not valid. | |
18 | Access denied. | |
19 | Device not found. | |
20 | Active Directory group synchronization domain controller not found. | |
21 | Active Directory group synchronization rule not found. | |
22 | Active Directory group synchronization is already enabled. | |
23 | Invalid password. | |
24 | Activation failed. | |
25 | Deactivation failed. | |
26 | The security token is not renewable. | |
27 | Trustee not found. | |
28 | A SQL error has occurred. | |
29 | Password too short. | |
30 | Password too weak. | |
31 | The password cannot contain the user name. | |
32 | The password has already been used before and cannot be reused. | |
33 | The password has expired. | |
34 | Password changing is not allowed. | |
35 | Invalid security token. | |
36 | User not enabled. | |
37 | Organizational unit boundary violation. | |
38 | Attribute definition not found. | |
39 | Claim definition not found. | |
40 | Invalid name. | |
41 | Insufficient licenses. | |
42 | License limit too small. | |
43 | The password reset time has expired. | |
44 | Mail notification configuration not found. | |
45 | Mail server not found. | |
46 | Mail notification template not found. | |
47 | Invalid search filter. | |
48 | Invalid activation key. | |
49 | Invalid search root. | |
50 | Invalid database or the license is being registered somewhere else. | |
51 | Mismatched site ID. | |
52 | License already in use. | |
53 | Database is already attached. | |
54 | The display name is already in use. | |
55 | Legacy realm already exists. | |
56 | A SQL database with the same name already exists. | |
57 | An error has occurred with the SQL connection. | |
58 | License not found. | |
59 | Resource not licensed. | |
60 | Feature not licensed. | |
61 | The object is currently in use by an Active Directory group synchronization rule. | |
62 | Database is still mounting. | |
63 | You cannot remove an identity provider with registered user accounts. Delete the appropriate user accounts before unregistering the identity provider. | There are registered Windows Active Directory or LDAP accounts hosted on this identity provider. Laserfiche Directory Server cannot remove the identity provider until all the accounts are removed from the site. |
64 | Number of resource should be non-negative. | |
65 | Invalid Cluster Configuration. | |
66 | Email address is not set. | |
67 | Cannot delete default mail server of the database or an organization. | |
68 | Cannot delete default mail template of the database or an organization. | |
69 | Temporary Password Expired | |
70 | Instance Limit Exceeded | |
71 | Agenda Manager Profile Limit Exceeded | |
72 | Database Limit Exceeded | |
73 | Forms Portal Limit Exceeded | |
74 | Full Concurrent User Limit Exceeded | |
75 | Public Portal Cpu Limit Exceeded | |
76 | Public Portal Dual Cpu Limit Exceeded | |
77 | Public Portal Multi Cpu Limit Exceeded | |
78 | Retrieval Concurrent User Limit Exceeded | |
79 | Security Profile Limit Exceeded | |
80 | Submitter Limit Exceeded | |
81 | Full Named User Limit Exceeded | |
82 | Restricted Named User Limit Exceeded | |
83 | Retrieval Named User Limit Exceeded | |
84 | Public Portal User Limit Exceeded | |
85 | Account Locked | |
86 | Certificate Not Found | |
87 | Federation Metadata Request Failed | |
88 | Invalid Federation Metadata Xml | |
89 | Unsupported Issuer Token Type | |
90 | Invalid Token Signing Certificate | |
91 | Expired Token Signing Certificate | |
92 | Missing Upn Attribute | |
93 | Permission Denied | |
94 | Invalid Escape Sequence | |
95 | Invalid Token Request | |
96 | Value Exceeds Max Length |
