Server Settings
System managers can configure the Laserfiche Server's settings: customize port handling, set a default repository, and configure system managers.
You will need to restart your Laserfiche Server service after modifying any of these values in order for the new values to take effect.
Note: This documentation includes instructions for volume operations in both the Laserfiche Repository Server Administration Tool and the Repository Desktop Administration Console. However, please note that the Repository Desktop Administration Console has been deprecated and we advise using the Server Administration Tool instead. See Deprecated Modules and Features for more information.
System Managers
In this section, you can view, add, or remove system managers to your system. See System Managers for more information. In addition to your user-defined system managers, members of the BUILTIN/Administration Windows group are also system managers.
To view, add, or remove system managers
  1. As a user with the system manager role, sign in to either the Repository Server Administration Tool or the Repository Desktop Administration Console.
  2. In the Server Administration Tool, select the Server Settings tab. In the Desktop Administration Console, select the System Managers node. The current list of system managers will be displayed.
  3. To add a system manager, do one of the following:
    1. Server Administration Tool: In the Add a new system manager option, type the user name for the user that you want to add as a system manager, or use the Browse (...) button to search for the user. Select Add.
    2. Desktop Administration Console: In the Action menu, select New Manager. Type the user name for the user that you want to add as a system manager, or use the Browse (...) button to search for the user. Select Add.
  4. To remove a system manager, select the user whose access you want to remove. Press the Remove or Delete button. The user will be removed immediately.
Settings
In the Settings section, you can configure connection information for your Laserfiche Server:
To modify Server settings
  2. In the Server Administration Tool, select the Server Settings tab. In the Desktop Administration Console, select the Server Settings node, open the Action menu and select Properties.
  3. Configure the following settings:
    • Listening port: The port on which the Laserfiche Repository Server will listen. The default is 80.
    • Notification port: The port on which the Laserfiche Repository Server will send notifications to other applications. The default is 5051.
    • LFAPI port: The port on which the Laserfiche Repository Server will communicate with LFAPI. The default is 1888.
    • Enable HTTPS: Select this option to enable a secure connection when applications connect to the Laserfiche Repository Server. The default is 443.
  4. Select Save to save your changes.
Default Repository
If you have multiple repositories, you can use the Default Repository option to determine which repository will be shown first upon signing in. If you have set a default repository, you can switch to another repository, typically by selecting the repository name.
  3. In the Default Repository option, select the repository that you want to set as default.
  4. In the Desktop Administration Console, select Save to save your changes. In the Server Administration Tool, your change will be saved immediately.
