Adding the Laserfiche Snapshot Printer
To print using Laserfiche Snapshot, it must be present under Printers and Faxes. If you have installed Snapshot on the current computer, it should already be there.
If this is the first time you are printing from a remote machine to a Snapshot printer, you will need to add the Snapshot printer before you will be able to use it. For more information on printing to a Snapshot printer remotely, see Setting up a Network Printer.
To add the Laserfiche Snapshot printer
  1. Click the Start button and select Control Panel.
  2. Open Printers and Faxes or Devices and Printers.
  3. Click Add Printer.
  4. In the Add Printer Wizard dialog box, click Next.
  5. Under Local or Network Printer, select A network printer, or a printer attached to another computer and click Next.
  6. Under Specify a Printer, select Connect to this printer and click Next.
  7. Under Browse for Printer, view the Shared printers list. Expand + the computer where Laserfiche Snapshot was installed, and select the Laserfiche Snapshot printer that appears. Click Next.
  8. Under Default Printer, if you plan to use Laserfiche Snapshot frequently, select it as your default printer.. Click Next.
  9. Under Completing the Add Printer Wizard, click Finish.
