Set-LocalNodeMaxConcurrentTaskPolicy
Synopsis
Sets the maximum number of tasks that the node will run at once.
Syntax
Set-LocalNodeMaxConcurrentTaskPolicy [-Automatic] <SwitchParameter>
Set-LocalNodeMaxConcurrentTaskPolicy [-NumberOfCoresOnNode] <SwitchParameter>
Set-LocalNodeMaxConcurrentTaskPolicy [-ExplicitNumber] <SwitchParameter> [-Number] <Int32>
Detailed Description
The Set-LocalNodeMaxConcurrentTaskPolicy function sets the policy that limits the number of tasks a node will run concurrently.
Laserfiche Distributed Computing Cluster currently supports three policies for setting the maximum number of concurrent tasks:
  • - Automatic: The Automatic policy uses a number that the service estimates will maximize throughput.
  • - NumberOfCoresOnNode: The NumberOfCoresOnNode policy uses the number of cores on the machine.
  • - ExplicitNumber: The ExplicitNumber policy uses a user specified number.
Parameters
-Automatic <SwitchParameter>
	Specifies that the automatic policy should be used to determine the maximum number of tasks that the node will run at once.
 	Required?                    true
	Position?                    1
	Default value
	Accept pipeline input?       false
	Accept wildcard characters?  false
-NumberOfCoresOnNode <SwitchParameter>
	Specifies that the number of cores on the machine should be used as the maximum number of tasks that the node will run at once.
	Required?                    true
	Position?                    1
	Default value
-ExplicitNumber <SwitchParameter>
	Specifies a that a user specified number should be used as the maximum number of tasks that the node will run at once.
	Required?                    true
	Position?                    1
	Default value
-Number <Int32>
	The user specified number that should be used as the maximum number of tasks that the node will run at once.
	Required?                    true
	Position?                    2
	Default value
Inputs
None
Outputs
None
Examples
Example 1
PS C:\> Set-LocalNodeMaxConcurrentTaskPolicy -NumberOfCoresOnNode
Sets the node to perform as many tasks at once as there are processor cores on that machine.
Example 2
PS C:\> Set-LocalNodeMaxConcurrentTaskPolicy -ExplicitNumber 5
Sets the node to perform a maximum of 5 tasks at once.
Example 3
PS C:\> Set-LocalNodeMaxConcurrentTaskPolicy -Automatic
Sets the node to use the automatic policy to determine the number of tasks that can be run at once.
Related Links
Get-LocalNodeMaxConcurrentTaskPolicy
Reset-LocalNodeMaxConcurrentTaskPolicy
