Configuring SSL
Configuring SSL Between the Laserfiche Mobile Server and the Laserfiche Server
Secure Socket Layer (SSL) is a cryptographic protocol used to encrypt and secure communications. You can configure SSL between the Laserfiche Mobile Server and the Laserfiche Server to provide extra security for information sent between the two.
Selecting this option on the Laserfiche Mobile Server Configuration page will enable the Laserfiche Mobile Server to connect to the Laserfiche Server using an SSL connection if SSL has been configured on the Laserfiche Server.
To configure SSL on the Laserfiche Server, see the Requirements for Using SSL/TLS with Laserfiche topic in the Laserfiche Administration guide.
Note: This is the not the same as configuring SSL between the Laserfiche Mobile Server and the internet browser.
Configuring SSL between the Laserfiche Mobile Server and the Internet Browser
To increase security, you may want to set up a TLS connection between the machine hosting the Laserfiche Mobile Server and the internet browser.
To set up an TLS connection between the Laserfiche Mobile Server and the internet browser, do the following
IIS 8 and later
  1. Open Internet Information Services (IIS) Manager.
  2. In the Connections pane on the left, click the computer name.
  3. In the IIS section in the middle of the screen, select Server Certificates.
  4. On the Server Certificates feature page, import or create a certificate for your site to use by selecting the appropriate option from the Actions pane.
  5. Under Connections on the left, double-click the computer name, double-click Sites, then select Default Web Site.
  6. Under Actions on the right, select Bindings....
  7. In the Site Bindings dialog box, click Add.
  8. In the Add Site Binding dialog box, select https from the Type drop-down list. In the SSL certificate drop-down list, select the certificate you created or imported in step 4.
  9. Click OK, then close the Site Bindings dialog box.
