Configuration Page
The Configuration page enables you to configure repositories the web client users can connect to. It also allows you to configure profiles, how users should authenticate to the web client, an SMTP Server for outgoing e-mail messages, watermark settings, if users can access the Configuration page remotely, and the web client logging levels. You must add at least one repository before you will be able to use the web client.
After you have installed the web client, you can find the Configuration page either through the Start menu or by typing the URL in your browser.
Note: The Configuration page can be automatically launched from the last step of the installation process by selecting Launch Laserfiche web client Configuration page.
The URL for the Configuration page is http://machinename/laserfiche/Configuration, where machinename is the name of the server where the web client is installed.
ClosedLanguage Picker
Select the default language you want the web client displayed in.
Troubleshooting Tips:
  • Server operating systems, such as Windows Server 2008, have an Enhanced Internet Security setting that requires all URLs (even those on your network) to default to the Internet zone. The Internet zone is usually set to a high security level, causing standard features that usually work on normal workstations, like JavaScript, to be disabled. When Enhanced Internet Security is enabled, the Configuration page may not be functional. Add the trusted the web client URL to the Intranet zone (which has lower security) and refresh the page to get the Configuration page to function correctly.
  • If adding a repository does appear to do anything and you are on Windows Server 2008 or later, User Access Control (UAC) may be affecting the page functionality. As a workaround, browse to the Config subfolder in the Web Files folder of your the web client installation folder. Accept the UAC prompt that appears and try to add your repository again using the web client's configuration page.
  • If you receive a "Retrieving the COM class factory for component with CLSID {E479E155-4F63-4E98-8B23-FCCFF569CA81} failed due to the following error: 800736b1" error message when adding a repository, you may need to restart the machine after installing the web client.
