Internet Information Services (IIS)
Laserfiche WebLink works with Microsoft's Internet Information Services (IIS) to provide access to the documents in the Laserfiche repository. WebLink requires Internet Information Services 8 or above. This section of the documentation describes some of the additional configuration that may be necessary.
Note: If you have an http redirect configured for your IIS site, and you upgrade or install a new version of WebLink, you will have to reconfigure the redirect for the new WebLink virtual directory. It will not inherit the existing redirect settings by default. Installing or upgrading WebLink will not change the default IIS settings.
Installing Required IIS Features
IIS offers a wide variety of configuration options, so the exact features you install may depend on your organization's needs. In addition to the features required for basic Web server functionality, make sure the following features are installed.
Features:
  • Static content
  • ASP.NET 4.5
  • Windows Authentication
To install these features
Note: The following instructions are for Windows Server 2012. Instructions will be similar but not identical on other versions of Windows. See Microsoft TechNet for information on other versions of Windows.
  1. Open Programs and Features.
  2. Select Turn Windows features on or off. The Add Roles and Features Wizard will open. Click Next.
  3. In the Installation Type step, select Role-based or feature-based installation. Click Next.
  4. In the Server Selection step, select the server you want to configure. Click Next.
  5. In the Server Roles step, expand Web Server (IIS) and Web Server and select the following features:
    • Static content (located under Common HTTP Features)
    • ASP.NET (located under Application Development)
    • Windows Authentication (located under Security)
  6. Click Next and proceed through the rest of the wizard.
  7. Restart if prompted.
Changing the Default Virtual Directory
The WebLink installation process automatically creates an IIS virtual directory for the WebLink website. A virtual directory points to the physical location where Laserfiche WebLink is actually installed. The virtual directory acts as the name of the URL that a user would specify to access WebLink. For example, the virtual directory name for a default WebLink installation is "WebLink." This means that to access the WebLink website, a user would specify "http://YourWebserverAddress/WebLink." If you would like to use a different name for your Laserfiche WebLink virtual directory, use IIS Manager to create a new virtual directory with the desired name.
Note:  The following instructions are for Windows Server 2012. Instructions will be similar but not identical on other versions of Windows. See Microsoft TechNet for information on specific versions of Windows and IIS.
Reducing Bot Traffic to WebLink
If WebLink is publicly accessible and uses an auto-login option, requests from bots and web crawlers can consume available repository connections and server resources. Add a robots.txt file to the root folder of the website that hosts WebLink to request that crawlers not access the public WebLink pages.
To request that crawlers not access WebLink
  1. On the WebLink web server, locate the root folder of the IIS website that hosts WebLink.
  2. Create a text file named robots.txt in the website's root folder. If a robots.txt file already exists, open it.
  3. Add the following directives:
    # Disallow all WebLink public pages
    User-agent: *
    Disallow: /WebLink
  4. If you changed the default WebLink virtual directory name, replace /WebLink with the custom alias. For example, use Disallow: /WebLink2 for an instance with the alias WebLink2.
  5. If the website contains multiple publicly accessible WebLink instances, add a separate Disallow directive for each alias.
  6. Save the file.
  7. In a web browser, navigate to https://YourWebserverAddress/robots.txt and verify that the file is publicly accessible and contains the expected directives.
Note: A robots.txt file provides instructions to crawlers but does not enforce access restrictions. Some crawlers may ignore it. For stronger controls, work with your IIS administrator to configure and test server-side restrictions, such as IIS URL Rewrite rules that block unwanted user agents or request patterns. Ensure that the rules do not block legitimate users or required services.
Configuring the .NET Trust Level in IIS
In Internet Information Systems (IIS), an application's Trust level determines the permissions that are granted to it by .NET code access security (CAS) policy. By default, IIS is configured with Full trust, meaning that unrestricted permissions are granted to applications. In order for WebLink to function correctly, IIS must be configured with Full trust.
To configure the .NET Trust level to Full in IIS
  1. Open the Internet Information Systems (IIS) Manager.
  2. In the Connections pane, expand the server name, then expand Sites.
  3. Expand Default Web Site, then select WebLink.
  4. Double-click .NET Trust levels.
  5. From the Trust level drop-down menu, select Full (internal).
  6. Click Apply.
