WebLink Designer
The WebLink Designer lets you configure WebLink to connect to your repositories, choose how you want users to authenticate to the repository, and customize various options in WebLink, both in appearance and in behavior. The WebLink Designer can be accessed at https://ServerName/Designer, where ServerName is the name of your WebLink web server.
Virtual Directories
You can manage your WebLink virtual directories in the top left corner of the WebLink Designer. By default, the original WebLink virtual directory will be listed here. If you have configured WebLink to use another virtual directory, or want to work with multiple WebLink virtual directories, you can add them by selecting Register and choosing from the list of available virtual directories on your web server. (See Changing the Default Virtual Directory for more information.) You can also remove virtual directories by clicking Manage. When configuring or customizing WebLink, ensure you have the appropriate virtual directory selected.
Configuration Options
The following sections of the WebLink Designer allow you to customize various aspects of WebLink:
