Custom Tabs
A custom tab allows you to display information from another website (whether another Laserfiche web application, a web application used at your site, or an external website) directly within the details pane. You can use tokens to customize what is displayed in this tab. For example, if you store tracking numbers for shipments in a “Tracking ID” field on your “Orders” template, you could create a custom tab for the carrier’s website using that field value as a token. When users selected the custom tab in the Details pane for a particular document, the tab would automatically open the carrier’s website and use the token to jump directly to tracking information for that order.
Custom tabs are created and modified in the Repository Web Client's Options page. Unlike most configurable elements in the Options page, custom tabs can be shared across users or groups, and require the Manage Repository Options privilege.
Creating a Custom Tab
  1. To create a custom tab, click your user name in the upper right corner of the folder browser or document viewer, and select Options, and then Display.
  2. In the Tabs section, select Add. The Custom Tab dialog box will open.
  3. In the Tab Name option, provide a name for the tab.
  4. In the Website URL option, specify the URL of the tab. When a user opens the specified custom tab in the Details pane, this page will load in that pane. You can use this to provide a link to a page in a Laserfiche product, such as a form, or to open an external website.
  5. Optional: You can use the token picker to customize this URL further. For example, you could use a "Customer ID" field to jump directly to a customer in your CRM software, or a Tracking Number field to open the tracking information for a specific package. Any field can be used in a custom tab, and the token will automatically be replaced by the information for that tab.
  6. In the Location option, select which Details pane or panes to use with this custom tab. You can select folder browser, document viewer, or both.
  7. By default, the new custom tab will be displayed in all folders, for all templates, and for all users. However, you can choose to display them only in specific contexts. For example, you might choose to only display your CRM tab for the "Customer Information" template and the "Sales" group.
    • Select Only display in specific folders to select one or more folders and, optionally, their subfolders.
    • Select Only display on specific templates to select one or more templates.
    • Select Only display for specific groups or users to select one or more trustees.
  8. Click OK to save your custom tab.
