Working with Document Contents
You can make changes to the contents of your documents: rearrange or remove pages, make changes to Microsoft Office documents, and make changes to other types of electronic files.
Checking Out a Document
You can check out a document before you begin working on it. Checking out a document will lock it so that other users can't make changes to that document until you have checked it back in, although they can still view it. All electronic documents can be checked out; in addition, documents without an electronic file can be checked out if they're under version control. When the Office Integration is installed, Microsoft Office documents are checked out automatically when you open them for editing, and will be checked back in when you save and close them.
Documents that you have checked out can be found in the Documents in Use section of your repository. See Starred Documents, Recent Documents and Documents in Use for more information.
Documents can be checked out manually by selecting the document in the folder browser, clicking the More button (
), and selecting Check Out Document, For electronic documents, you can also right-click them and select Check Out Document. If the document has image pages, you can also check it out by opening it in the document viewer, clicking the document name in the upper left corner, and selecting Check Out Document. (You can also check out Microsoft Word documents manually in this way if you do not want them to be checked back in as soon as you close Office.)
When you are done making changes to a checked out document, you can check it in by selecting the document and selecting Check In Document from either of the same menus. You can also discard your changes by selecting Undo Check Out.
If a document is under version control, all of the changes that you make during a single check out will be saved in a single version.
Working with Image Pages
If you are working with a document that contains pages (including PDFs, but not including documents with an electronic file such as a Word document or Excel spreadsheet), you can rearrange those pages, move them from one document to another, use them to create a new document, or delete them.
Once you have made a change to a document, until you save it, it will be locked for editing and cannot be modified by other users. It will also appear in the Documents in Use section of your repository. See Starred Documents, Recent Documents and Documents in Use for more information.
Rearranging Pages
You can rearrange pages within your documents, either in the folder browser or in the document viewer. In the folder browser, the page thumbnails will be on the right, in the Preview tab; select the Thumbnails button to view the pages as thumbnails. In the document viewer, thumbnails will be on the left. To rearrange them, select a page or pages and drag it, then drop it where you want to place it.
Rotating Pages
If a page is accidentally scanned sideways or upside-down, you can rotate it to its correct orientation. To rotate a page, select the page and click the Rotate Clockwise button, or right-click the page and select Rotate Clockwise. Continue to do this until the page is correctly rotated.
Moving Pages Between Documents
You can move pages between documents in the folder browser. Select a document and then click the Thumbnails tab on the right to display the page thumbnails. Select a page or pages, then drag it onto a document to move the pages into the document, or onto a folder to create a new document with those pages in the specified folder.
You can also move or copy pages by selecting the pages and then clicking the Move Pages To (
) or Copy Pages To (
) button, or selecting and right-clicking the page thumbnails, and navigating to the location where you want to move the pages.
Generating Pages from PDFs
By default, pages will be generated from PDFs when they're imported into the repository, allowing you to use Laserfiche annotations on the contents, rearrange and rotate pages, and use other document viewer tools. If a PDF has been imported into the repository without pages generated, or if you need to update the pages, you can manually generate pages.
To do so, select the PDF document in the folder browser. Click the More button (
) and select Generate Pages. If the document already has pages, you will be prompted to confirm that you want to overwrite those existing pages.
Deleting Pages
To delete pages, open the document in the document viewer and select the thumbnail for the page or pages you want to delete. Press the DELETE key. Deleted pages will go to the recycle bin; see Deleting Documents and Folders for more information.
Working with Microsoft Office Documents
The Office Integration is a Laserfiche component that allows users to work with Microsoft Word documents, Excel spreadsheets, and PowerPoint presentations from their repository in the native Microsoft Office applications for Windows. The Office Integration allows you to save Office files directly to your repository from the Office ribbon or toolbar, and to interact with local copies of documents through the Windows System tray.
The tray app allows users to check-in, check-out, and perform other operations on documents they have downloaded locally.
Note: The Repository Desktop Client does not use the tray app. All functions are performed from within the Laserfiche ribbon in Microsoft Office applications.
Installing the Office Integration
If you have never used the Office Integration on your workstation before, you will need to install it. You can do so by opening any Microsoft Office document in your repository. You will automatically be prompted to download and install the Office Integration. This will save a file to your computer, which you can run to install the Office Integration. Once you have installed the Office Integration, you may be prompted to close any Microsoft Office applications you have open, and/or to restart your computer. If you are not prompted to do so, you will need to close and re-open your Office applications after installing.
Making Changes to a Microsoft Office Document
Once the Office Integration has been installed, you can open Microsoft Office documents by selecting them in the folder browser, and they will open in the appropriate Microsoft Office application. You may make changes to the document and its metadata. Your document will remain checked out until you close the document. If you used the Check out context menu, you will need to use the Check in button or menu option in the tray app. If you opened the document using the Edit with… option, it will be automatically checked back in for you. You may also manually check in the document or undo the check out within the repository. A shortcut in the Windows system tray provides quick access to a list of documents you have checked out locally using the Repository Web Client. The local copies of the documents are automatically deleted once they are no longer needed for synchronization with the Laserfiche repository.
Saving to Laserfiche from a Microsoft Office Application
The Laserfiche ribbon Save to Laserfiche button is used when adding a document to the repository for the first time.
This ribbon will not be shown when working with existing Laserfiche documents from the Web Client, and all actions will be performed from the tray app, including the option to Save as a new document.
Working in the Repository Desktop Client
The Office Integration has a number of features to help you work with your documents. To access them in your Office application, select the Laserfiche tab. You can choose to immediately save the document to Laserfiche, manually check it in, make version comments if the document is under version control, and modify field, tag, version, and link information directly from the Office integration. You can also add tokens to your Office document that will draw information directly from your repository, such as the document's name or creator, and field values.
Note: Editing metadata and using tokens from the repository are not available for the Web Client Office integration at this time. You can use the View in Web Client option to easily open the corresponding document in the Web Client to work with metadata.
Working with Other Electronic Files
You can make changes to other types of electronic files by checking out the document and opening it for editing. The document will be saved locally on your computer. When you are done making changes, check the document back in. You will be prompted to upload the updated version of the document, which will replace the existing file.
Working with Document Metadata
All documents and folders contain various metadata, including both user-created metadata such as fields, tags, links, and versions, and other information such as the document's name, location, creation and modification date, and so on. For more information on working with document metadata, see Metadata.
Generating Document Text
By default, Laserfiche will automatically try to generate text from electronic files and PDFs when they are imported into the repository. A background service monitors for newly imported documents and queues newly created documents for OCR. In addition, text will be generated for scanned documents, documents printed using Snapshot, and documents imported using Import Agent.
If you need to update the text, you can manually generate text. To do so, select the document in the folder browser. Click the More button (
) and select Generate Text. If the document already has pages, you will be prompted to confirm that you want to overwrite those existing pages.
Note: Text cannot be generated for documents with pages but without an electronic file or PDF portion if they are already in the repository.
The text generation process runs in the background and results may not be immediately available. Larger documents may be processed in chunks. For documents under version control, you may see several versions created as text is generated.
