Installing the Laserfiche Distributed Computing Cluster Service
Distributed Computing Cluster uses a group of machines to perform work for Laserfiche applications. Before it can be used, the Distributed Computing Cluster service must be installed as a Scheduler on one machine. For multi-node clusters, Distributed Computing Cluster must be installed as a Scheduler on one machine and as a Worker on one or more other machines.
To install the Laserfiche Distributed Computing Cluster Service
  1. Open the Laserfiche Installer.
  2. Locate Distributed Computing Cluster and click Install.
    Distributed Computing Cluster in the Laserfiche Installer
  3. After successfully extracting and installing, the installer will open the Distributed Computing Cluster Configuration Utility.
  4. Use the utility to configure whether the installed instance of Distributed Computing Cluster will be run as a Worker or a Scheduler as well and configure the service user account. If the installer does not open the utility, the utility can be located at the following default location: C:\Program Files\Laserfiche\Distributed Computing Cluster\bin\DistributedComputingClusterUtility.exe.
Note: The installer's default behavior will treat Distributed Computing Cluster as an application that requires a license. If no license is configured in the Installer, a license warning will be displayed. This warning can be ignored when Distributed Computing Cluster is configured to run as a Worker. A Distributed Computing Cluster license is required only when configuring the service to run as a Scheduler.
