Modifying, Repairing or Removing an Installation
To repair a Laserfiche installation using Add/Remove Programs
- Open the Control Panel from the Start menu.
- Open Add/Remove Programs or Programs and Features, depending on your operating system.
- Locate the Laserfiche component you want to repair or remove.
- Right-click and select Change to repair components or uninstall specific sub-components, or Uninstall to remove all components of the selected item.
- Follow the directions to complete your modify, repair or remove operation.
