Tags
Tags are a metadata type in Laserfiche that provide a way to categorize documents and folders. You can use tags to indicate information such as the entry's status, contents, or handling instructions. Tags are used to categorize entries on an entry-by-entry basis. You can also use tags to help with document retrieval, since you can search for documents categorized with a particular tag.
See Best Practices for Using Tags.
Free Training: Using Metadata in Laserfiche 12 eLearning course in Aspire.
You can also use tags to restrict access to specific documents. See Security Tags for more information.
Viewing, Adding, and Removing Tags
You can view the currently-assigned tags, add tags, or remove tags from the right pane of both the document viewer and the folder browser.
  1. Select a document or folder in the folder browser, or open a document in the document viewer.
  2. Select the Details tab in the right pane. Any currently-assigned tags will be displayed under Tags.
  3. Do one of the following:
    • To add a tag, click Add and select a tag from the list. You can also add a new tag by typing a new tag name in this option. See Creating and Deleting Tags, below, for more information.
    • To remove a tag, click Edit. Click the X icon to the left of the name of the tag you want to remove.
  4. Click Done.
Note: If the tag you are applying is a security tag, only users who have been granted that tag will be able to see the document to which it is applied. Security tags are marked with the security tag icon. See Security Tags for more information.
There are two ways to create a tag. You can quickly create a tag from within a document or folder, or you can create a tag in Repository Administration. You can only create security tags, or delete tags, in Repository Administration.
Creating a Tag while Working with a Document or Folder
  3. To add a tag, click Add and type the name of your new tag.
  4. Click Done.
Creating a Tag in Repository Administration
  1. Open the Repository Web Client and select your user name in the upper right, then select Administration.
  2. On the left, under Metadata, select Tags.
  3. Select the Add button (The Add button, a dark gray plus sign.) to add a new tag.
  4. In the Name option, type a name for the tag.
  5. Optional: In the Description option, type a description for the tag.
  6. Optional: If you want to create the tag as a security tag, select Security tag.
  7. Click OK to save the new tag.
Deleting a Tag
To delete a tag in the Web Client, open Tags, select the tag you want to remove, and click the Delete button.
Free Training: Metadata Administration eLearning course in Aspire.
