Enabling and Disabling Branches
For activities that contain branches, you can change the operational status for each branch. Disabled branches are not run when the workflow runs and will be grayed-out in the Designer Pane. All branches are enabled by default. You may want to disable branches if you only want to test specific sections of your workflow.
To enable/disable branches
  1. Right-click an activity's branch in the Designer Pane.
  2. Select .
