Determining a Workflow's Current Status
When troubleshooting a workflow that is not performing properly, it is important to know its current status.
See a video about checking the status of a workflow.
To determine a workflow's status
- In the Search Pane, search for the workflow you want to check the status of. Search results will appear in the Search Results Pane.
- Look for a workflow instance in the Search Results Pane that matches the name and start time of the workflow in question.
Note: If no such workflow instance appears, the workflow never started.
- Look at the
Status column. A workflow can have one of four statuses: Running, Waiting, Completed, or Terminated.
