Error Code Range: 600-699
600 - UnknownLicenseActivationError
Unknown license activation utility error.
601 - LicenseActivityToolLoggingFailure
Activation utility failed.
602 - StartingRuleUpdateQueryTimedOut
Rule update has timed out.
603 - UnsupportedMigrationVersion
The migration does not support version {0}.
604 - ConditionMigrationFailed
Could not read condition xml. The root element is missing.
605 - TheLicenseActivationToolCouldNotBeFound
The license activation utility '{0}' could not be found.
606 - TransferDownloadLockCouldNotBeAcquired
Could not acquire the download transfer lock, try again.
607 - DownloadTransferAborted
Could not continue download.
608 - InvalidDirectoryConfigurationElement
Unsupported directory element detected. Please contact Laserfiche Support. Name='{0}'; Type='{1}'; Profile='{2}'
609 - ConfigurationMigrationError_MissingElement
Configuration file is corrupt, missing element '{0}'.
Workflow 8.0 is not installed or the install directory could not be detected.
611 - RuleAutoNameFailed
A unique rule name could not be generated.
612 - CommunicationIdentityFailed
Unable to load certificate identity.
613 - InvalidStatusDate_NotValidDate
The Status Date is not a valid date.
614 - InvalidStatusDate_GreaterThan
The Status Date must be greater than {0}.
615 - InvalidStatusDate_LessThan
The Status Date must be less than {0}.
616 - InvalidStartDate_NotValidDate
The Start Date is not a valid date.
617 - InvalidStartDate_GreaterThan
The Start Date must be greater than {0}.
618 - InvalidStartDate_LessThan
The Start Date must be less than {0}.
619 - SecuredUserAlreadyExists
The user '{0}' already exists.
620 - FileBrowserNotEnabled
The Workflow Server does not have file browsing enabled.
621 - InvalidFileFilter
The list of file types must contain at least one valid file type.
622 - InvalidFileFilter_NotEven
623 - InvalidFileFilter_Empty
The list of file types must not be null or empty.
624 - StartingRuleTypeMismatch
The starting rule being updated is of one rule type and the information being used to update it is for another rule type.
625 - InvalidWfxFile_MissingDesignerTag
The .wfx file is invalid.
626 - MigrationFailed_CouldNotFindRootActivity
Could not find the workflow definition xml in the file being migrated.
627 - InvalidWfiFile_MissingExportedWorkflowsTag
The .wfi file is invalid. It does not contain any workflows.
628 - LinkFailed_ConnectionProfileEmpty
Subscriber Connection {0} did not have any xml for repository {1}.
629 - RuntimeHostAlreadyInitialized
The workflow runtime host has already been initialized.
630 - RuntimeHostNotInitialized
The workflow runtime host has not been initialized.
631 - WorkflowRuntimeNotFound
Workflow runtime {0} not found.
632 - ScriptCalledFromDefaultAppDomain
ExecuteEntryPoints cannot be called from the default app domain.
633 - InvalidZoomLevel
The ZoomLevel {0} is invalid.
634 - ParentAlreadySet
The ActivityUI.Parent property can only be set once.
635 - DesignerScriptExecuteTimeout
The script has taken more than {0} seconds to run. Would you like to keep running the script?
636 - DuplicateRegisteredRepository
The repository {0} has already been registered.
637 - SessionReset
The session has been reset by the server.
Column '{0}' is returning a large amount of data: {1}. Consider using the Custom Query activity to exclude this column.
639 - InstanceAlreadyRunning
Workflow '{0}' did not start because an instance is already running.
640 - SubscriberUpdateNotRecent
The Workflow Subscriber has not sent an update in a few minutes. Check the subscriber error log for communication errors.
641 - PublishedFailed_ClosedWindow
Workflow '{0}' could not be published because its window has been closed.
642 - FailedToFindTaskExecutorType
Failed to find task executor type '{0}'. Name = '{1}', Task = '{2}'
643 - LicenseStatus_GracePeriod
The workflow service is in its grace period.
644 - LicenseStatus_Expired
The workflow service license is expired.
645 - LicenseStatus_NotLicensed
The workflow service is not licensed.
646 - InvalidLicenseVersion
Invalid license version.
647 - UnexpectedXMLWhileLoadingActivity
The Designer has encountered an unexpected {0} while loading the activity '{1}' from XML. The {0} has been ignored. Verify that the ReadProperties method is implemented correctly for '{2}' activities.
648 - FailedToTransferAttachedPropertyCollection
The Designer encountered an error while copying {0} from '{1}' to '{2}'. You may need to transfer this information manually.
649 - NonDocumentWaitingOnExtensionChanged
The wait condition has been canceled because non-documents can not wait on extension changes.
650 - ConditionEntryWasDeleted
The condition entry was deleted.[{0}]
651 - ScriptAssemblyCouldNotBeLoaded
The assembly '{0}' could not be found to load into the script app-domain.
652 - DataSourceRequiredToTestQuery
The data source must be specified to test the query.
653 - AttemptedToStartWorkflowRuntimePrematurely
An attempt to start the workflow runtime prematurely was detected.
654 - AttachmentNotFound
The attachment '{0}' could not be found.
655 - AttachmentFoundByIdInsteadOfName
Using attachment with name '{0}' since the specified attachment '{1}' could not be found. To resolve this warning republish the workflow with the correct attachment.
657 - StampNotFound
Stamp not found: {0}
658 - PageDoesNotHaveImage
The page does not have an image. The annotation must be placed on a page with an image.
659 - InvalidNumber
{0} is not valid for the '{1}' property.
660 - NotAListField
The field '{0}' is not a list field.
661 - FieldNotFound
The field '{0}' was not found.
662 - SharePointServerNotFound
The server '{0}' could not be found.
663 - SharePointListItemCouldNotBeCreated
The list item could not be created.
664 - InvalidResponseReceivedFromSharePointServer
Invalid response received from server.
665 - NoSharePointServerFound
No server is currently set.
666 - SharePointFolderCouldNotBeCreated
The folder '{0}' could not be created.
667 - NewNameWasBlank
The specified new name could not be used because it was blank.
668 - SharePointListItemCouldNotBeFound
The specified list item could not be found or was not set.
669 - SharePointListItemCouldNotBeDeleted
The specified list item could not be deleted.
670 - SharePointListItemWasNotCreated
The list item could not be created. This error is sometimes due to not setting required fields.
671 - ActivityIterationLimitReached
The activity's iteration limit ({0}) has been reached.
672 - ServerIterationLimitReached
The Workflow Server's iteration limit ({0}) has been reached.
673 - WebServiceAlreadyExists
A web service already exists with the name '{0}'.
674 - NotSupportedByWorkflowServer
The requested operation is not supported by this version of the Workflow Server.
675 - CertificateCouldNotBeVerified
The certificate could not be verified. Make sure the issuer is in the Trusted Root Certification Authority.
676 - NewOwnerWasBlank
The specified new owner name could not be used because it was blank.
677 - TrusteeMustBeAUser
The trustee must be a user.
678 - RequiresLF90OrHigher
This feature is only available when using Laserfiche 9.0 Servers and higher.
679 - UnableToFindConnectionProfile
Unable to find connection profile matching Laserfiche Server '{0}' and repository '{1}'.
680 - EntryWithIdNotFound
Could not find entry with ID '{0}'.
681 - EntryWithNameNotFound
Could not find entry '{0}'.
682 - RequiresWF90OrHigher
This feature is only available when using Workflow 9.0 Servers and higher.
683 - CanNotDeleteLatestVersion
The workflow '{0}' version '{1}' cannot be deleted because it is the latest version of the workflow.
684 - BPAlreadyRegistered
The business process '{0}' could not be registered because another process is registered by source: '{1}'
685 - DuplicateRoleName
A role with the name '{0}' already exists.
686 - EmptyRoleName
The role's name must be specified.
687 - BusinessProcessNotFoundNameId
Could not find business process '{0}'. Id= {1}
688 - MustConfigureWorkflowWebServices
The Workflow Web Services must be configured before publishing a business process workflow.
689 - NumberPercisionExceeded
Number fields are limited to 5 decimal places.
690 - NumberFieldOutOfRange
Number fields must be between -9,999,999,999,999 and 9,999,999,999,999.
691 - EntryTypeMismatch
The entry found at '{0}' was a document when a folder was expected. Using the document's parent folder instead.
692 - ExtraParameterReturned
The following output parameters were not expected: {0}. Refresh the parameters and republish the workflow to resolve this issue.
693 - InvokeSynchronizationDisabled
Synchronization disabled. The notification queue address is empty. Check the error logs for more details.
694 - InvokeSynchronizationDisabledOnServer
Workflow Server {0} does not support synchronization.
695 - BadBPConnectionProfile
Client features for business processes require a connection profile to a Laserfiche 9.0 Server or higher.
696 - NoBPProfileSpecified
The business process could not be registered because the business process profile was not specified.
697 - NoWorkflowInitiator
The workflow does not have an initiator.
698 - ParticipantCouldNotBeFoundFromValue
The participant '{0}' could not be found.
699 - ExpectedOutputErrorsNotReturned
The following output parameters were expected but not returned: {0}
