Error Code Range: 700-799
700 - MaximumInvokeDepthReached
701 - InvalidEndDate_NotValid
The End Date is not a valid date.
702 - NotificationTemplateAlreadyExists
A notification template already exists with the name: {0}
703 - ActionSkippedDueToHoliday
Notification was not sent because it occurred on a holiday.
704 - BusinessProcessInstanceNotFoundById
The business process with ID '{0}' was not found in the database.
705 - BusinessProcessInstanceWasAlreadyClosed
The business process instance '{0}' has already ended.
706 - BusinessProcessEntityWasAlreadyClosed
707 - InvalidDueDate_NotValid
The Due Date is not a valid date.
708 - NoManagerWasFoundForTrustee
No manager was found for trustee '{0}' in directory '{1}'.
709 - StepParticipantsBindingNotSet
The reference to the step participants was empty or not set. The participants were not updated.
710 - ScriptAssemblyNotFoundOnPublish
Script assembly file '{0}' was not found. Scripts may not run correctly for workflow '{1}'.
711 - UserDoesNotHaveAFolderAssigned
User '{0}' does not have a folder assigned.
712 - GroupDoesNotHaveAFolderAssigned
Group '{0}' does not have a folder assigned.
713 - ErrorCommunicatingWithLaserficheServer
Error communicating with Laserfiche Server '{0}': {1}
714 - ProcessNotDeleted_WrongSource
The Laserfiche Business Process '{0}' was not deleted from repository '{1}' due to it being owned by '{2}'.
715 - StepReferenceWasEmptyAndCouldNotBeClosed
The reference to the step was empty or could not be found. The step could not be closed properly.
716 - NotificationPortProbablyFirewalled
The subscriber service could not listen to notifications. This is most likely due to a firewall blocking the notification port {0} on Laserfiche server {1}
717 - BusinessProcessActivity_Warning_ReportingIdTooLong
Reporting IDs cannot be longer than {0} characters. The given reporting ID is too long and will be truncated to '{1}'.
718 - NotificationEmailNotFound
No destination e-mail was found for the notification to account name '{0}'.
719 - MaximumFileUsingFormFieldsRetrieved
Only {0} collection or table fields can be retrieved at one time.
720 - FailedToStartDisabledBusinessProcess
Failed to start business process '{0}' because it is currently disabled
721 - DefaultVolumeMissingForReplication
Could not replicate to the folder '{0}' since it does not have a default volume.
722 - ContextedLockTimedOut
The activity stopped waiting for the synchronization context with ID '{0}' because it reached the maximum wait time ({1}).
723 - LockContextIsNullOrEmpty
No synchronization occurred because the synchronization ID was empty.
724 - DpsEndPointNotFound
Could not connect to the scheduler. Ensure the following: (1) the host name and port are correct, (2) the scheduler node is on, and (3) the firewall is not blocking the connection.
725 - Dps_DefaultNotFound
Default scheduler does not exist.
726 - Dps_ServerNotFound
The selected scheduler does not exist.
727 - ExportAsImage_Error
Failed to export workflow as an image.
728 - WebServiceNotSynchronized
The Web service '{0}' was not found on the Workflow Server. It needs to either be configured or reassigned.
729 - DPSServiceNotSynchronized
The Distributed Computing Cluster Scheduler '{0}' was not found on the Workflow Server. It must be configured or reassigned.
730 - HadInvalidCookieContainerParameter
The cookie container passed into the workflow was invalid.
731 - HadTwoCookieContainerParameter
Two cookie containers (binary and XML) were passed into the workflow. Only the binary cookie jar will be used.
732 - ConnectionRedirectFailed
Connection redirect '{0}' with ID {1} failed because: {2}
733 - ConnectionRedirectFailedDefaultSucceeded
The original workflow connection profile succeeded.
734 - ConnectionRedirectFailedAnotherSucceeded
Redirect '{0}' with ID {1} succeeded.
735 - MustBeABusinessProcess
The workflow must be a business process.
736 - ExchangeServerNotFound
Exchange server ‘{0}’ not found.
737 - GenericInvalidFieldValueError
Value for field ‘{0}’ was not valid.
738 - Exchange_NoFieldsConfigured
No fields were configured.
739 - ExchangeItemCouldNotBeFound
Exchange Item could not be found.
740 - MaximumFilesAttached
Only {0} files can be attached per email.
741 - MaximumAttachmentSize
ICalendar files can only support up to 1MB of attachments. Additional attachments will be ignored.
742 - AccessIsDenied_StartWorkflow
Access Denied. {0} does not have permission to start the business process.
743 - DuplicateSearchFilterName
‘{0}’ already exists; please rename the search filter and save again.
744 - DuplicateWorkflowFolderName
Adding folder ‘{0}’ failed because another folder already has the same name.
745 - BPFilterRequirementCheck
The entry ‘{0}’ did not match the filter requirements. Please review the starting instructions.
746 - BPMetadataFilterRequirementCheck
The entry ‘{0}’ did not match the filter requirements. {1}.
747 - NotAnAuthorizedFormsMachine
The machine '{0}' is not an authorized Forms server for starting workflows.
748 - RemoteEndpointRequired
The remote endpoint was not set. This is a required message property for starting a workflow directly.
749 - AuthenticatedUsersAreRequriedToStartWorkflows
Anonymous users are not allowed to start workflows.
750 - WorkflowCompletionContextExpired
Completion of instance ‘{0}’ of workflow ‘{1}’ failed due to completion lifetime expiration. {2}.
751 - DpsModuleNotConnected
The Distributed Computing Cluster Module ‘{0}’ is not enabled for the specified host.
752 - DocumentHadNoPages
The source document contained no pages.
753 - WorkflowVersionHasBeenDeleted
Workflow definition has been deleted.
754 - EntryHasNoEDoc
The document ‘{0}’ does not have an attached electronic document.
755 - UnknownAttachmentNotFound
An attachment could not be found.
756 - EmailServerNotFound
The email server ‘{0}’ could not be found.
757 - FormsServerNotConfiguredForWorkflow
The forms server ‘{0}’ is not configured to interact with this workflow server.
758 - CanNotChangeServerWhilePublishing
The workflow server cannot be changed while publishing.
759 - LFUserTokenNotPresentAndIsRequired
Ensure your Laserfiche software is up to date.
760 - LFUserTokenNotUnderstoodUpgradeRequired
The workflow server encountered errors starting the business process. Ensure your Laserfiche software is up to date.
761 - LFServerConnectionError
{0}. Please make sure the server name is correct and you have specified the correct port information.
762 - RequiresLFS104OrHigher
This feature is only available when using Laserfiche Server 10.4 or higher.
763 - RequiresLFS103OrHigher
This feature is only available when using Laserfiche Server 10.3 or higher.
764 - PatternCannotBeEmpty
The pattern cannot be empty.
765 - LongitudeCannotBeEmpty
The longitude cannot be empty.
766 - LatitudeCannotBeEmpty
The latitude cannot be empty.
767 - GeoCoordinateNotValid
The value ‘{0}’ is not a valid number.
768 - GeoCoordinateOutOfRange
The value ‘{0}’ is not in range.
769 - AccessIsDenied_ManageAdminRights
Access is denied. User ‘{0}’ does not have enough rights to perform this action.
770 - AccessIsDenied_ManageAdminRightsSelf
Access is denied. User ‘{0}’ cannot change administrative rights of themself.
771 - AccessIsDenied_ManageAdminRightsGroup
Access is denied. User ‘{0}’ cannot change administrative rights of their member groups.
775- GetAllOrganizationsFailed
Failed to retrieve the list of all organizations.
776- GetAllIdentityProvidersFailed
Failed to retrieve the list of all identity providers.
777 - CreateLfdsGroupFailed
Group '{0}' not registered successfully: {1}
778 - DeleteLfdsTrusteeFailed
Trustee not unregistered successfully: {0}
779 - CreateLfdsUserFailed
User '{0}' not registered successfully: {1}
781 - GetAllLicenseTypesFailed
Failed to retrieve the list of all license types.
782- GetAllFeaturesFailed
Failed to retrieve the list of all features.
783 - AssignLicenseFailed
Could not assign license to user '{0}': {1}
784 - AssignTrusteeToGroupFailed
Could not assign trustee '{0}' to group: {1}
785- InvalidFieldAccessWarning
The field '{0}' could not be accessed. {1} [{2}]
786- OAuthClientUnauthorized
The OAuth Client is unauthorized. Please authorize first.
787- CertificateNotFound
The certificate '{0}' could not be found.
788 - AIServerNotFound
AI server '{0}' not found.
789 - AITranslatingTextFailed
Could not translate text. The original text is used as result.
Warning: {0}
790 - CustomAITaskFailed
Could not perform AI task: {0}
791 - NotLicensedForAIFeature
The workflow service is not licensed for AI feature.
792 - SignDocumentDeprecated
The Sign Document activity is deprecated and will not be executed.
