Displaying Documents in a Form
You may want to display documents in a form while the user is filling out the form. This can be done by embedding the document in an IFrame on the form page. Insert the following custom HTML code using the Custom HTML option in the Layout page of the form designer:
<iframe height=620px width= 870px src=DocumentURL></iframe>
You can adjust the height and width used in the above sample to suit your users' needs.
It is also possible to change the document displayed based on a user's input elsewhere on the form.
