Sections
Sections are visually distinct, collapsible segments of a form. Each field placed under a section is part of that section.
Sections can be read-only. For example, if you want a form to be read only but you still need users to sign it, put all the fields, except the Signature field, in a section and set it to read-only.
Settings
Editing a Section in the Form Designer
- Select the section on the canvas, and the options will appear in the right pane.
- Under Field label, enter the name that will appear above the section on the form.
Note: The header for a section in a form is an h2 header, not an h1 header. Only the header of the form can be an h1 header.
- Under the Text above field and Text below field, you can enter any additional text that should appear with the section. Click the Insert Variable button to include a variable with this text.
- Under Display Options, select Read-only to make the fields in this section read-only. Users cannot edit read-only fields.
- Under Section Label Options, choose among the following options:
- Show the section label, border, and text above field (selected by default): This option shows these elements of the section on the form. De-selecting this option is useful if you want to make a section of your form read-only (see Step 5) and not have the visual clutter of section headings.
- Allow users to collapse and expand this section: If you choose to show the section label, you can select to allow users to collapse or expand the section. Selecting this option will display an expand/collapse button next to the section label. You can choose the default state for the section from the drop-down menu that is displayed when this option is selected.
- To configure advanced options, click the Advanced tab.
- Under Tooltip, specify the help text that will appear when users hover over the field.
- Under CSS classes, specify the CSS classes to assign this field. Learn more about using CSS.
- Select the Rules tab to create field rules specific to this field. Learn more about using rules.
- Your changes will be applied to the form automatically.
Editing a Section in the Classic Form Designer
- Select the section on the canvas and click Edit.
- Under Section label, enter the name that will appear above the section on the form.
- Under Section label options, choose among the following options:
- Hide the section label, border, and the text below the label: This option hides these elements of the section on the form. This option is useful if you want to make a section of your form read-only (see Step 5) and not have the visual clutter of section headings.
- Allow users to collapse and expand this section: If you choose to show the section label, you can select to allow users to collapse or expand the section. Selecting this option will display an expand/collapse button next to the section label. You can choose the default state for the section from the drop-down menu.
- Under Text below field, you can enter any additional text that should appear with the section. Click the Insert Variable button to include a variable with this text.
- Under Section options, select Read-only to make the fields between this section and the next section (or the end of the form) read-only. Users cannot edit read-only fields.
- Under CSS class, specify a CSS class to assign this section. Learn more about using CSS.
- When you are finished editing the settings, click Done. Your changes will be applied to the form automatically.
