Authentication Errors (1 – 99)
| 1 | The authentication information was not provided in the correct format. Please verify the value of the Authorization header. |
| 2 | Authentication failed. |
| 3 | Incorrect password |
| 4 | Authentication ticket is not properly formatted. |
| 5 | The account type cannot be retrieved from claims. |
| 6 | The server cannot create a new authentication item. |
| 7 | You cannot create more access_id/secret pairs for API access because you have already have {0} {1}. |
| 8 | You do not have sufficient rights to view this page. |
| 9 | You are not authorized to perform this action. |
| 10 | You are not authorized to perform this action. Please contact your system administrator for more information. |
| 11 | The username or password is incorrect. |
| 12 | Unable to connect to Laserfiche. |
| 13 | The user '{0}' was unable to authenticate to SQL Server '{1}'. |
| 14 | Your Windows account lacks sufficient rights to SQL Server '{0}'. |
| 15 | Forms cannot connect to the Laserfiche Server. Your email has not been updated. Please try again later or contact your Laserfiche administrator. |
| 16 | The connection has been disabled. |
| 17 | An error occurred during sign-in. Please try again or, if the issue persists, contact your system administrator. |
| 18 | Entity Framework returned the following error when trying to communicate with SQL Server: {0}. |
| 19 | Account connection expired due to inactivity. |
| 20 | Your session expired. A draft of your work was saved. |
| 21 | The participant user who tried to sign in does not have a license. |
