Business Process Controller Errors (2600 – 2699)
You may encounter one of the following business process errors. Please match the error message with one of the following values.
Business Process Controller Error Codes
| Status Code |
Error Message |
| 2600 |
Access denied. Only process administrators can delete instances.
| 2602 |
Laserfiche Forms encountered an error while saving process data. |
| 2603 |
Failed to retrieve users. |
| 2604 |
There are no custom error messages to export. |
| 2605 |
Friendly name cannot contain any of the following characters: " ", "#", ":", ".", "<", ">", "%", "/", "?", "+", "&", "*", "\". |
| 2606 |
The file cannot be downloaded from Solution Templates at the moment. Please try again later. |
| 2607 |
An error occurred while importing this process from the Solution Templates. |
| 2608 |
Downloading process modeler timed out. Please try again later. If the problem persists, please contact your system administrator. |
| 2609 |
An error occurred while generating the process image. Please try again later. |
| 2610 |
Instance not found. It may have been deleted already. |
| 2611 |
The business process list is empty. |
| 2612 |
Participant name cannot be empty. |
| 2613 |
Downloading process image failed because the canvas size is too large. |
