Form Controller Errors (2100 – 2199)
You may encounter one of the following errors involving a business process or form. Please match the error message with one of the following values.
| 2101 | This business process '{0}' is not published. |
| 2102 | The business process cannot be found. |
| 2103 | The process associated with the page you are trying to view has been deleted. Please contact your Laserfiche administrator for more information. |
| 2104 | The form you are looking for cannot be found. It has either been submitted or removed. |
| 2105 | An error occurred while retrieving your form. Please try resubmitting your request later. |
| 2106 | Invalid form data was sent to the server. This can occur if the form is out of date. Please refresh this form and try again. |
| 2107 | An error occurred while processing your request. Please try resubmitting your data again later. |
| 2108 | This task has been reassigned and is no longer available to you. |
| 2109 | Unable to access a process with a start event or timer start event through a URL. |
| 2110 | Invalid form data was sent to the server. This can occur if the form is out of date. Please refresh this form and try again. {0} |
| 2111 | One or more form fields contain illegal character combinations (e.g., "&# or '<' next to (a-z, /, ?, !)"). Please resubmit the form without these characters. |
| 2112 | This task has been locked because a submission has already occurred but has not been processed. |
| 2113 | reCAPTCHA is enabled but a valid reCAPTCHA response cannot be found. |
