Formula Errors (1000 – 1999)
You may encounter one of the following errors when a formula cannot be evaluated. Please match the error message with one of the following values. Learn more about formulas
| 1000 | '{0}' is an invalid formula expression. |
| 1001 | Unable to divide {0} by zero. |
| 1002 | Unable to divide by zero. |
| 1004 | A parameter was not a valid value. |
| 1006 | The function '{0}' was given an invalid number of arguments. |
| 1007 | A function was given an invalid number of arguments. |
| 1008 | An error occurred while parsing a formula. |
| 1009 | An error occurred while calculating a read-only field's formula. |
| 1011 | '{0}' cannot be used as a logical value. |
| 1012 | '{0}' cannot be used as a numeric value. |
| 1013 | Invalid date |
| 1014 | '{0}' cannot be used as an integer value. |
| 1015 | The index '{0}' was out of range. |
| 1016 | Some formulas that were entered cannot be evaluated because a proper evaluation order could not be found. |
| 1017 | '{0}' is not a supported function for use in a formula. |
