Generic Errors (500 – 599)
- Laserfiche Forms 9.2.1 or earlier: Go to the Windows Logs > Application Event Log in the Windows Event Viewer.
- Laserfiche Forms 10 or later: Go to the Applications and Services Logs > LFForms Event Log in the Windows Event Viewer.
| 500 | Laserfiche Forms encountered an internal error. Please try again. |
| 501 | Forms cannot connect to the Laserfiche Routing Service because the service is not running. |
| 502 | An unexpected error has occurred. |
| 503 | Unauthorized Ajax call |
| 504 | An error occurred while attempting to query Active Directory. Please check that the Active Directory domain controller specified in Forms Configuration is correct, and then try again. |
| 505 | Database Context is null. |
| 506 | The page you are trying to view has timed out. Please reload the page. |
| 507 | Your submission was not processed because the Laserfiche Forms Routing Service is currently unavailable. If the problem persists, contact your system administrator. |
| 508 | The instance cannot be deleted. This may be because the instance cannot be found, is still in progress, or has already been deleted. |
