Report Errors (9600 – 9699)
You may encounter one of the following report errors. Please match the error message with one of the following values. Learn more about reports
| 9600 | A snapshot named '{0}' already exists. Please choose a different name. |
| 9601 | Snapshot not found. It may have been deleted already. |
| 9602 | The snapshot must have a name. |
| 9603 | The snapshot is still being generated. Please try again later. |
| 9611 | View not found with ID: {0} |
| 9612 | Custom report not found. It may have been deleted already. |
| 9613 |
The report name already exists. Please choose a new one. |
| 9614 | The table does not contain any columns. Please update the table configuration. |
| 9615 | No group by column is configured for the summarized table. Please update the summarized configuration. |
| 9616 | No category or series is configured for the chart. Please update the chart configuration. |
| 9617 | The business process associated with this operational report has been deleted. |
| 9618 | Aggregation result exceeds the maximum numeric value. |
| 9619 | Report visualization has been updated. Please refresh the page and try downloading the report again. |
| 9620 | Cannot download the report as an image or PDF because the report does not contain a chart. |
| 9621 | Cannot download chart report as a CSV file. |
| 9622 | A schedule named '{0}' already exists. Please choose a different name. |
| 9623 | Schedule not found. It may have been deleted already |
| 9624 | Cannot generate chart report as a CSV file. |
| 9625 | You do not have any instances. |
| 9626 | Snapshot generation failed. Please check and resolve any errors in the report definition. |
| 9627 | The DateTime {0} represents an invalid time in {1}, and is thus skipped. The next trigger time will be {2}. |
| 9628 | This instance has been partially deleted through your data maintenance policy. |
