| 300 |
The requested URI does not represent any resource on the server. |
| 302 |
The requested version '{0}' of service '{1}' does not exist. |
| 303 |
Form name is not provided. |
| 304 |
A form with that name already exists. Please provide a unique name. |
| 305 |
Another business process is already using this URL. Please specify a unique URL. |
| 306 |
This form cannot be submitted while the honeypot field contains a value. |
| 307 |
The business process must have a name. |
| 308 |
The requested page is no longer available. |
| 309 |
The business process cannot be found. |
| 310 |
The requested form does not exist. |
| 311 |
The requested form does not exist. Please ensure that the correct form is selected in the message start event and try again. |
| 313 |
The submission does not exist. |
| 314 |
Unable to retrieve submission. |
| 315 |
The process cannot be found via form. |
| 316 |
This action can only take place on a global process. |
| 317 |
Error reading XML file - {0}. |
| 318 |
There is no user with SID {0}. |
| 319 |
The process cannot be found via instance. |
| 320 |
The process instance cannot be found via submission. |
| 321 |
The business process cannot be found via instance ID. |
| 322 |
Form attachment cannot be found by attachment ID '{0}'. |
| 323 |
Invalid XML detected |
| 324 |
No account is configured to archive the form submission to Laserfiche |
| 325 |
No account is configured to archive the form submission to Laserfiche. |
| 326 |
The PDF generator was not installed correctly. |
| 327 |
No form is selected in the task named '{0}' in the '{1}'. |
| 328 |
Failed to call wkhtmltopdf.exe |
| 329 |
Timeout expired for exiting call to wkhtmltopdf.exe. |
| 330 |
The form submission did not start any routing. |
| 331 |
Missing sections due to corrupted web.config file. |
| 332 |
Schema exists in this database. |
| 333 |
An error was encountered while updating passwords. This issue can occur if the FIPS is enabled. |
| 334 |
Failed to parse URL: Invalid URL |
| 335 |
Failed to register the Laserfiche repository: {0}
| 336 |
Failed to configure Save to Repository: {0} |
| 337 |
There must be at least one table or stored procedure in the SQL database to assign it to a business process. |
| 338 |
This account does not have sufficient rights to download form attachments. |
| 339 |
This task has been completed. |
| 340 |
This task was canceled. |
| 341 |
The process has been modified and this user task has been deleted.
| 342 |
This theme is used by other forms and cannot be deleted. |
| 343 |
The form that you modified is out of date. Please refresh the form and submit again. |
| 344 |
The username already exists. |
| 345 |
The form '{0}' is used in this business process and cannot be deleted. |
| 346 |
Invalid secret key |
| 347 |
The Laserfiche Discussions server, used for Frequently Asked Questions, cannot be reached. Please contact your Laserfiche Administrator and ensure the Laserfiche Discussions section of Forms Configuration is correctly configured. {0} |
| 348 |
The variable {0} is not a sub-member of variable {1} |
| 349 |
System default entities cannot be modified. |
| 350 |
A process named '{0}' already exists. |
| 351 |
The user '{0}' requires the Manage Trustees privilege. |
| 352 |
The name '{0} ... {1}' of {2} (ID: {3}) in the process '{4}' exceeds the maximum length 200. |
| 353 |
The Laserfiche Forms agent account is not configured. The Forms agent user (FORMSUSER$) is an internal user which is created when you configure your Laserfiche repository and admin account. Please contact your system administrator. |
| 354 |
No starting step found. |
| 355 |
External data source cannot be found (ID: {0}). |
| 356 |
No history entry for the instance (worker instance ID: {0}) was found. |
| 357 |
The user task cannot be found. |
| 358 |
No form was found by routing step (business process ID: {0}, step ID: {1}). |
| 359 |
The LDAP participant cannot be found. |
| 360 |
Failed to verify the LDAP configuration. ({0}) |
| 361 |
You cannot delete yourself. Please sign in as a different user and try again. |
| 362 |
The LDAP server profile is not configured. |
| 363 |
No document relationship was configured. |
| 365 |
The variable name '{0}' already exists. Please provide a unique name. |
| 366 |
The form does not exist for the business process (ID: {0}). |
| 369 |
The account name used for Save to Laserfiche is invalid. |
| 370 |
The Laserfiche document (entry ID: {0}) is checked out by another user or application.
| 371 |
No Laserfiche folder exists at the path '{0}'. |
| 373 |
The user could not be enabled. A user with that name is already enabled. |
| 374 |
| 375 |
You must sign in to download form attachments. |
| 376 |
The submitted form no longer exists. |
| 377 |
You cannot change your own role. Please sign in as a different user and try again. All other changes have been saved. |
| 378 |
Lookup failed to retrieve data from tables. |
| 379 |
You cannot change the role of the account used to synchronize users with Laserfiche Directory Service. |
| 380 |
The process step configured within the task '{0}' is not valid or has not occurred. |
| 381 |
The draft name is empty. |
| 382 |
The worker instance with ID {0} was not found. |
| 383 |
Cannot upgrade the version number |
| 384 |
The length of the name has exceeded the maximum limit. |
| 385 |
The process name already exists. Please choose a new one. |
| 386 |
The process name '{0}' already exists. Please choose a new one. |
| 387 |
The due date cannot be set before the current time. |
| 388 |
Worker instance {0} is not suspended. |
| 389 |
The file you are trying to upload no longer exists. |
| 390 |
Step from the same instance is being performed right now. Please try again later. |
| 391 |
The following variable names are duplicates: {0}. Please provide unique names. |
| 392 |
Cannot access inactive user. |
