Routing and Runtime Errors (700 - 899)
You may encounter one of the following errors when you s process fails to run properly. Please match the error message with one of the following values.
Routing and Runtime Error Codes
| Status Code |
Error Message |
| 701 |
The draft you are trying to submit has already been submitted. |
| 702 |
The draft you are trying to submit was deleted. |
| 703 |
The routing XML contained duplicate nodes with the same member ID but no repeat ID. |
| 704 |
The draft cannot be found. |
| 705 |
The redirect URL '{0}' is invalid. |
| 706 |
An error occurred while running the process. Please make sure Laserfiche Forms is configured properly. Manually restart Laserfiche Forms Routing Service to ensure that all necessary changes take effect. |
| 707 |
The submission you are trying to retrieve is not a draft. |
| 708 |
The submission data does not match the current variables assigned to this process. |
| 801 |
There is no team with ID {0}. |
| 802 |
The task {0} was not reassigned to a team. |
| 803 |
This team task has not been assigned yet. |
| 804 |
This task has already been assigned to another user. |
| 805 |
You cannot reassign a task to the person it is currently assigned to. |
| 806 |
This task cannot be reassigned. |
| 807 |
You do not have the team access rights to perform this task. |
| 808 |
There is no team with name '{0}'. |
| 809 |
This task has a saved draft and cannot be approved/rejected through direct approval. |
| 810 |
The task does not have email notification enabled. |
| 811 |
The task is suspended and has no email recipient. |
