Troubleshooting
Windows Event Viewer
Laserfiche Forms error logs are visible from the Windows Event Viewer on the machine where the Forms server is installed. Under Applications and Service Logs, go to Laserfiche, Forms, and then Apps. You can use the following channels:
- Admin: Log events that require administrator intervention.
- Operational: Log events that are more expected during normal operation.
- Debug: Log the most number of events to help with debugging. Note that this channel does not show by default. You can view the channel by selecting the App node and then select View Analytic and Debug Logs from the View menu. To enable the channel, right-click the channel and click Enable Log.
Using the Diagnostics Tab
The Diagnostics page in Laserfiche Forms allows you to select a log level, as well as enable or disable tracing, to help you troubleshoot a specific problem.
More Information
The most common issues are covered in the FAQ section of the help.
For more information about a particular error or issue, search Laserfiche Answers or the Support Site for related KB articles.
