Token Formatting--Empty Tokens
You can format a token so that when you create the token with a blank value (or an empty string), the blank value is replaced with "NULL," instead of remaining blank. Do this by including the string "NULL" in the token format, as in %(TokenName#"NULL"#).
Example: Formatting using NULL in an empty token:
| Input Test: | 45 |
| Input Value: | %(Entry Name#"NULL"#) |
| Output Test: | 45 |
| Output Value: | NULL |
