Actions on Documents
This section focuses on actions that are specific to documents, such as checking out, viewing them in the document viewer, saving, streaming, and locking.
Opening and Checking Out Documents
[Settings]OpenEdocAsDoc
If TRUE, electronic documents (except PDFs) are opened in the document viewer by default. This can be set manually by the user in Tools → Options → View → Open With, as pictured in the Windows client:
In the web client, this attribute can be changed by selecting the relevant option under Select default behavior for opening an electronic file in Options → Display:
Valid values:
- TRUE/FALSE
Default value: FALSE
[Settings]OpenPDFAsDoc
Specifies whether to open PDFs in the Laserfiche document viewer by default. This can be set manually by the user in the same dialog box referenced in [Settings]OpenEDocAsDoc.
Valid values:
- TRUE/FALSE
Default value: TRUE
[Settings]OpenPagelessWithMetadataDlg
Specifies whether to open pageless documents in the metadata dialog box by default. This setting is effective only if [Settings]OpenEDocAsDoc or [Settings]OpenPDFAsDoc (depending on your file type) are already TRUE.
The user can also set this attribute to TRUE by selecting, in the dialog box described in [Settings]OpenEDocAsDoc, The Metadata dialog box under "Open zero-page documents by default using:".
This setting does not apply to the web client.
Valid values:
- TRUE/FALSE
[Settings]OpenEdocReadOnly
Determines whether electronic files that are not PDFs are opened in read-only mode by default. The user can configure this in the same dialog box described in [Settings]OpenEDocAsDoc.
Valid values:
- TRUE/FALSE
[Settings]OpenPDFReadOnly
Determines whether PDFs are opened in read-only mode by default. The user can configure this in the same dialog box described in [Settings]OpenEDocAsDoc. This attribute does not apply to the web client.
Valid values:
- TRUE/FALSE
[Settings]OpenPDFUsingWebDAV
Determines whether PDF files are opened using WebDAV by default. The user can configure this in the same dialog box described in [Settings]OpenEDocAsDoc. This attribute does not apply to the web client.
Valid values:
- TRUE/FALSE
Default value: TRUE
[Settings]OpenEdocsUsingWebDAV
Determines whether electronic files that are not PDFs are opened using WebDAV by default. The user can configure this in the same dialog box described in [Settings]OpenEDocAsDoc.
This attribute is not available for the web client.
Valid values:
- TRUE/FALSE
Default value: TRUE
[Settings]EdocOpenAttempts
Determines how many times Laserfiche will attempt to open an electronic file before concluding that it is already open elsewhere. Windows client only.
Valid values:
- Integers.
Default value: 6
[Settings]OpenOnCheckOut
Determines whether to open documents immediately upon checking them out. The user can change this attribute by selecting or clearing "Open document for editing immediately" in the Check Out dialog box. This attribute applies to the Windows client only.
Valid values:
- TRUE/FALSE
Default value: TRUE
[HiddenDialogs]ConfirmUndoCheckout
Determines whether a confirmation dialog box appears when a user attempts to undo a checkout. Applies to the web client only.
Valid values:
- Integers. Set to 6 to hide dialog box. Delete attribute to show dialog box.
[HiddenDialogs]DeleteModifiedDocOnUndoCheckout
When the user clicks "Undo check out" on a modified document, this attribute determines whether a dialog box appears asking them whether to delete the local copy.
Valid values:
[Options]ElectronicFileExportPath
Determines the temporary directory that is used when an electronic file is opened. Windows client only.
Valid values:
- String representing path
Default value: Path for user's local temporary directory
[Settings]PromptOfficeSelection
Determines whether to open Microsoft Office documents using Office 365 or the Laserfiche Office Integration. Applies to the web client only.
Valid values:
- Integers. 0 = Use Office 365, 1 = Use Laserfiche Office Integration, 2 = Ask the user.
Default behavior: Ask the user
[WebAccess]PromptDownloadOfficePlugin
If FALSE, the prompt to download the Laserfiche Office Integration, which usually appears when the user opens or checks out a document without having the integration installed, will be turned off. Applies to the web client only.
Valid values:
- TRUE/FALSE
Default value: TRUE
[Settings]OpenInPDFViewer
Determines whether to open PDF files in an embedded PDF viewer within the document viewer. Applies to the web client only.
Valid values:
- TRUE/FALSE
[WebAccess]StreamMedia
Determines whether audio and video files will be streamed upon opening. This is the same setting as Stream media files under Options → Display. Applies to the web client only.
Valid values:
- TRUE/FALSE
Default value: TRUE
Saving or Checking In Modified Electronic Documents
[Options]ElectronicImportOption
Determines the default option when saving a modified electronic document that is not under version control. Windows client only.
Valid values:
- Integers. 0 = Discard modifications, 3 = Save as new document, 4 = Overwrite existing document.
Default value: 3
[Options]ElectronicImportOptionCheckIn
Determines the default option when saving a modified electronic document that is under version control. Windows client only.
Valid values:
- Integers. 0 = Discard modifications, 2 = Save a new version of the document, 3 = Save as new document, 4 = Overwrite existing document.
Default value: 3
[Options]ElectronicImportOptionLink
Determines the default option when saving a modified electronic document that is in a relationship with other documents. Windows client only.
Valid values:
- Integers. 0 = Discard modifications, 1 = Make a new link with the modified document, 3 = Save as new document, 4 = Overwrite existing document.
Default value: 3
[Options]ElectronicNewVersionDelete
Determines whether the option to delete the temporary file on disk when saving a modified electronic document is selected by default. Windows client only.
Valid values:
- TRUE/FALSE
Default value: TRUE (option to delete temporary file selected by default)
[HiddenDialogs]ConfirmCheckIn
Determines whether a confirmation dialog box appears when the user attempts to check in a document. Windows client only.
Valid values:
[HiddenDialogs]VersionImportOptions
After a user saves changes to a document as either a new version, a new document, or the same document, this attribute determines whether a dialog box appears asking them what to do with the changes. Windows client only.
Valid values:
- -1 to hide dialog box. Any other value shows the dialog box.
Default behavior: dialog box is shown.
[HiddenDialogs]DeleteOnCheckIn
When the user checks in a document, this attribute determines whether a prompt appears asking whether to delete the local copy of the document.
Valid values:
[HIDDENDIALOGS]ConfirmSaveDocument
When this attribute is not set, a dialog box will pop up when the user makes changes to a document and tries to exit the document viewer. If the user clicks "Don't ask me again" in this dialog box, or if they clear the "Save document" box in Options → Reset → Prompts, this attribute will be set to 6 in their trustee attributes, and the dialog box will not appear on future occasions. To bring back the dialog box, delete the attribute from the user's trustee attributes. After you delete the attribute, the change will take effect when the cache of user attributes next updates.
Valid values:
- Integers. Set to 6 to disable dialog box. Delete attribute to enable dialog box.
Deleting Documents or Pages
[HIDDENDIALOGS]ConfirmPageDelete
Asks users if they really want to delete a page when they attempt a delete a page. When this attribute is not set, a confirmation dialog box pops up when the user attempts to delete the page. They can click "Don't ask me again" to disable this dialog box in the future, or they can clear the "Page delete" box in Options → Reset → Prompts. Either way, their [HIDDENDIALOGS]ConfirmPageDelete attribute will be set to 6.
Valid values:
[HiddenDialogs]DeleteEmptyDoc
Determines whether a confirmation dialog box appears when a user moves all of one document's pages to another document. The dialog box asks if the user wants to delete the former document.
Valid values:
- Integers. 6 disables the dialog box. Delete attribute to enable dialog box.
[HiddenDialogs]ConfirmDeleteEDoc
Determines whether a confirmation dialog box appears when a user attempts to delete an electronic file from a document. Web client only.
Valid values:
[Options]DeleteElectronicFiles
Specifies whether temporary electronic document files will be deleted from disk when they are no longer needed. Windows client only.
Valid values:
- TRUE/FALSE
Default value: TRUE
Other Actions
[Options]PromptForVolumeOnCopy
Specifies whether to prompt for the destination volume when copying a document. Windows client only.
Valid values:
- TRUE/FALSE
[HIDDENDIALOGS]ConfirmMoveCopy
When this attribute is not set, a dialog box will pop up when the user tries to copy and paste a document. If the user clicks "Don't ask me again" in this dialog, this attribute will be set to 6 in their trustee attributes, and the dialog box will not appear in future copy-and-paste attempts. To bring back the dialog box, delete the attribute from the user's trustee attributes. After you delete the attribute, the change will take effect when the cache of user attributes next updates.
Valid values:
[WebAccess]MoveOrCopyDefault
Determines the default option selected in the Move or Copy dialog box. Does not apply to the Windows client.
Valid values:
- String. "move" = Move selected by default, "copy" = Copy selected by default.
[Settings]InsertBeforePage
Specifies where to insert pages in a document. When this attribute does not exist, a user who tries to insert pages into another document will encounter a dialog box asking them where in the document to insert the pages. Windows client only.
Valid values:
- Integers. 0 = Insert pages before the first page, -1 = Insert pages after the last page, -2 = Ask user where to insert, -3 = Default location (usually the last option used).
Default value: -1
[Settings]ElectricFileFailedWaitTime
Specifies the time (in milliseconds) to wait after opening an electronic document before monitoring it for local changes. Windows client only.
Valid values:
- Integers
Default value: 5000
[Settings]ElectricFileWaitTime
Specifies the time interval (in milliseconds) at which an open electronic document will be polled for local changes. Windows client only.
Valid values:
- Integers
Default value: 500
[Options]AddRepEdocDirectory
Determines the default folder that opens in the Windows File Explorer when you browse for documents to add in the Add/Replace Electronic File dialog box. Windows client only.
Valid values:
Default value: The last path that the user added an electronic file from.
[HiddenDialogs]InsertBeforePage
Specifies whether a dialog box pops up asking the user where to insert pages in a document.
Valid values:
- Yes = Do not show dialog, No = Show dialog.
Default behavior: Dialog box appears.
[HiddenDialogs]ConfirmReleaseLock
Specifies whether the user gets a confirmation dialog box when they try to release a lock on a document. Web client only.
Valid values:
- Integers. 1 = Show dialog box, 6 = Do not show dialog box.
