General Attributes
These are client-wide settings or administrative settings for the Repository Web Client or Repository Desktop Client.
Language and Locale
By default, the Repository Web Client will determine language and locale based on the language settings of the user's browser. Language determines the language that strings appear in, while locale determines how numbers are formatted how dates and times are formatted, and what calendar to use. If the user prefers a different language or locale from the default ones determined from the browser, they can change [Settings]Language, [Settings]Locale, and [Settings]Calendar. These three attributes do not affect the Repository Desktop Client. Language in the Desktop Client is controlled by [Options]LanguageISO, while the locale is taken from the locale of the Windows system.
See the OCR page for OCR language settings.
[Settings]Language
Allows you to set the language that strings appear in for the Web Client. This overrides the browser's default settings. It does not affect locale settings.
Valid values:
- Strings corresponding to locale names, e.g. "en-US", "th", "ar-KW".
[Settings]Locale
Web Client only. Overrides the default locale settings that were determined from the browser. The calendar specified by this setting is overridden by [Settings]Calendar.
Valid values:
Default value: en-US
[Settings]Calendar
This attribute is used to determine the calendar used in the Web Client, overriding both the user's web browser settings and the calendar set in [Settings]Locale. It does not affect non-calendar locale settings, such as number formats and date formats.
Note: Some calendars are not compatible with certain locale settings. If [Settings]Calendar specifies a calendar that is not compatible with the prevailing locale settings, then the Web Client will use the default calendar for that locale.
Valid values:
- String. Possible values are as follows:
gregorian= Gregorian calendarislamic-civil= Tabular Islamic calendar with leap years 2, 5, 7, 10, 13, 16, 18, 21, 24, 26 and 29 in a 30-year cycleislamic-fatimid= Fatimid Islamic calendarislamic-saudi= Umm al-Qura calendarislamic-kuwaiti= Tabular Islamic calendar with leap years 2, 5, 7, 10, 13, 15, 18, 21, 24, 26 and 29roc= Minguo calendarchinese= Chinese lunisolar calendarhebrew= Hebrew lunisolar calendarbuddhist= Thai Buddhist solar calendarindian= Indian national calendarpersian= Solar Hijri calendarcoptic= Coptic (or Alexandrian) calendarethiopic= Ethiopian calendar set to the Amete Mihret eraethiopic-amete-alem= Ethiopian calendar set to the Amete Alem eradangi= Korean lunisolar calendar
Default behavior: Gregorian calendar
Determines the language used in the Desktop Client. This value is read from the registry after it is set.
Valid values:
- Strings representing the language, in the form of two-letter ISO codes (e.g. "en" for English).
Default value: en
[Settings]showLocalizedNameOnly
Determines whether the display will use only the names of objects in the local language, or whether it will use both the original (English) names and the names in the local language. Web Client only.
Valid values:
- TRUE/FALSE
Default value: TRUE
Display Options
[Settings]Window
The initial position of the primary window in the Repository Desktop Client. Remembered from the user's last session.
Valid values:
- Manually altering the value of this attribute is not recommended. We recommend configuring the desired value in the Desktop Client, then exporting and importing it to share it between users.
[Settings]SubWindow
The initial position of the secondary window in the Desktop Client. Remembered from the user's last session.
Valid values:
[Settings]NotificationTimeLimit
The length of time, in seconds, that toast notifications in the Repository Web Client will be displayed before disappearing.
Valid values:
- Integers
Default value: 4
[Settings]InitialOptionsPage
Determines the section of Tools → Options in the Desktop Client that is first displayed.
Valid values:
- Integers. Set to 6 to hide dialog box. Delete attribute to show dialog box.
[Settings]DelayedProgressTimeout
The time (in milliseconds) an operation takes before a delayed progress bar shows up. Desktop Client only.
Valid values:
- Integers
Default value: 5000
Repository Web Client Management
[HiddenDialogs]ConfirmSaveMetadataInfo
Determines whether a confirmation dialog box appears when the user changes metadata settings in the Repository Web Client's management page and attempts to navigate to another tab within the Metadata section (e.g. from Fields to Templates) without saving their changes.
Valid values:
Default behavior: Dialog box appears.
[HiddenDialogs]ConfirmSaveGeneralInfo
Determines whether a confirmation dialog box appears when the user changes settings in the General section of the Web Client's management page and attempts to navigate to another tab within the General section (e.g. from Settings to Group Watermarks) without saving their changes.
Valid values:
[HiddenDialogs]ConfirmSaveAdminInfo
Determines whether a confirmation dialog box appears when the user changes settings in the Web Client's management page and attempt to navigate to a different section in the left pane (e.g. from Metadata to Everyone in the screenshot) without saving their changes. This settings does not apply to navigation between tabs in the main (right) pane.
Valid values:
[HiddenDialogs]ConfirmSaveUserInfo
Determines whether a confirmation dialog box appears when an administrator modifies trustee information in the Web Client's management page and attempts to navigate to a different tab in the Users section before saving their changes. Web Client only.
Valid values:
Default behavior: Dialog box is shown.
[HiddenDialogs]ConfirmSaveIntegrationInfo
Determines whether a confirmation dialog box appears when an administrator changes information about integrations in the Web Client's management page and does not save changes before navigating to a different tab within the Integrations section.
Valid values:
[HiddenDialogs]ConfirmEndTask
Determines whether a confirmation dialog box appears when the user cancels an action in the Web Client's management page.
Valid values:
Security
[HiddenDialogs]EncryptLocalStorage
Determines whether the user's data that is stored locally on the browser will be encrypted. Repository Web Client only.
Valid values:
- TRUE/FALSE
Default value: TRUE
[Settings]CopyACL
Determines whether access rights are copied when entries are copied.
Valid values:
- TRUE/FALSE
Default value: TRUE
[Settings]ShowInheritedRights
This sets the default value for the "Show inherited rights" checkbox in the Entry Access dialog box. Repository Desktop Client only.
Valid values:
- TRUE/FALSE
Default value: TRUE
Recent Documents and Folders
[Settings]RecentDocumentLimit
Determines the number of recently used documents to remember. This list is used in a wide variety of contexts, such as in choosing documents for exporting.
Valid values:
- Integers
Default value: 10
[Settings]RecentFolderLimit
Determines the number of recently used folders to remember.
Valid values:
- Integers
Default value: 10
[Settings]BufferRecentFolders
Determines whether to store the list of recently used folders locally before committing it to the server at a later time.
Valid values:
- TRUE/FALSE
Default value: TRUE
[Settings]BufferRecentDocuments
Determines whether to store the list of recently used documents locally before committing it to the server at a later time.
Valid values:
- TRUE/FALSE
Default value: TRUE
Others
[Settings]AutonameCounter
Sets the value of the current count token.
Valid values:
- Integers
[Settings]AutoResetHiddenDialogs
Determines whether the user's hidden dialog settings will be reset when they next sign in. Repository Desktop Client only.
Valid values:
- TRUE/FALSE
Default value: FALSE
[Settings]RemovedFeatures
This disables certain Laserfiche features (e.g. Snapshot) for the particular user. Desktop Client only.
Valid values:
- A comma-delimited string of features to disable (e.g. "Records Management,Snapshot")
[Settings]MaxClientWorkerThreads
The maximum number of simultaneous worker threads to allow. For example, an import may be in a different worker thread from a page-generating process. Desktop Client only.
Valid values:
- Integers
Default value: 10
[Settings]NewTrusteeFilter
Determines which trustees are listed in the Entry Access dialog box and in the trustee picker in the Advanced Search pane. The latter is the dialog box that appears when you select View → Advanced Search → Customize Search → User, then click ... in the User section in order to select trustees.
This attribute applies to the Desktop Client only.
Valid values:
- Integers representing an enumerated type with a flags attribute. 1 = Laserfiche groups, 2 = Laserfiche users, 4 = Windows groups, 8 = Windows users, 10 = LDAP groups, 20 = LDAP users, 40 = Directory Server groups, 80 = Directory Server users, 100 = Everyone group.
Default behavior: All trustees enumerated above are included.
