Laserfiche Default Network Ports
This topic lists the default network ports for Laserfiche products and components. It also includes a section on ports used to communicate with non-Laserfiche services.
Most of these ports can be changed in the products' administration consoles or configuration files.
Note: Unless otherwise noted, the ports listed apply to version 12 products and components. For older versions of products and components, refer to the whitepaper Default Network Ports for Laserfiche Products.
Administration Hub
- 7055 for communication between the Administration Hub Controller and Administration Hub Agent machines.
Audit Trail
Version 11
- 5081 for Laserfiche Audit Trail Importing Service
- 5082 for Laserfiche Audit Trail Reporting Service
- 5085 for Laserfiche Audit Trail Event Hub Service (Update 4 or newer)
- 443 (IIS HTTPS port) for the reporting and administration website
- 10256 for the queue port in Laserfiche Audit Trail Event Hub to receive audit events (Update 4 or newer)
Connector
Version 11
When connecting with a third-party browser-based application, Connecter uses the following ports by default:
- Chrome: 9222
- Firefox: 6000
- Edge: 9322
Directory Server
- 5048, 5049 for HTTPS with the service
- 443 (IIS HTTPS port) for the administration website
- 5055 for licensing notifications to Laserfiche Server
- WMI Ports for looking up host IDs and fingerprints. Please see Microsoft’s documentation on securing remote WMI connections.
Distributed Computing Cluster
Version 10
- 8107, 8108
Email Archive
- When using IMAP, Laserfiche Email Archive automatically ensures port 25 is open between Laserfiche Email Archive and your email server.
Forms
- 80 for HTTP, 443 for HTTPS
- 8168 for lfrouting
- 8268 for lfpushnotification
- 8170 for attachmentTransfer
- 8181 for the Notification Hub Service
- 8732 for lfautotrigger
- 8736 for lfformexport
- 8738 for lflicensing
- 8176 for lfinstance
- 8174 for lookup
Full Text Indexing and Search Engine
- 5053
Laserfiche Authentication Service (Repository Web Client and Web Administration Console)
Version 10
- 8188
Laserfiche Mobile App Server
Version 11
- 8089 for OCR service
- 8188 for Laserfiche Authentication Service
For Forms notifications:
- 8268 for Laserfiche Notification Master Service
- 8181 for Laserfiche Notification Hub Service
- 8189 for Laserfiche App Notification Services
Note: Ports 8089 and 8188 are used for communications internal to the server, so you do not need a firewall rule to allow inbound traffic for these ports.
Laserfiche Repository Server
- 80, 5051
- 443 when TLS is enabled
Quick Fields
Version 11
- Agent: 8092
- Server: 80 (HTTP)
- Server with Secure Port (SSL/TLS/HTTPS): 443
- 8188 for the Laserfiche Authentication Service
Weblink
Version 11
Workflow
- 8085 for communication between Workflow Server and its clients (Workflow Designer, Workflow Administration Console)
- 80 for HTTP, 443 for HTTPS for communication between Forms and Workflow and for Laserfiche clients to start Laserfiche business processes
Ports for non-Laserfiche Services
Laserfiche products often need to communicate with other services. Make sure that Laserfiche products are able to communicate with these other services as needed. Default ports commonly used by other products include:
- SQL Server's TCP 1433 port
- Email servers often use ports 25 and 587
- Microsoft Message Queuing Service uses Port 1801
The Microsoft Developer Network offers several resources on ports and firewalls. The first link below lists common ports.
