Web Client URLs
You can use URLs to navigate to entries or search results in the Repository Web Client, to determine how content is displayed, and to perform actions on entries.
Note: The following syntax assumes that the Web Client is communicating using SSL. If this is not the case, replace https:// in the URL with http://
Base URL
The base URL for the Repository Web Client takes the following form:
- https://ServerName/laserfiche
where ServerName is the name of your Web Client server computer, or of your domain. All URL options build on this base URL.
Open to a Specific Folder
You can create a link that will open the Repository Web Client directly to a specific folder. To do so, use the following URL:
- https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID
where dbName is the name of your repository and EntryID is the entry ID of the folder. You can find the entry ID in the Web Client in the Metadata tab of the details pane, under Show advanced. This URL can also be obtained by navigating to the folder and opening it in the Web Client, then copying the URL from the address bar.
You can also choose to show the specified folder as the root of the repository. Folders other than the specified folders and its children will not be displayed in the folder tree. To do so, use the following URL:
- https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&view=newroot
Note that the new root URL option will only take effect if the link is used when the user is logged out; it will not take effect if used while a user is logged in.
Open to a Document in the Document Viewer
You can create a link that will open the Repository Web Client directly to a specific document. To do so, use the following URL:
- https://ServerName/laserfiche/docview.aspx?db=dbName&id=EntryID
where dbName is the name of your repository and EntryID is the entry ID of the document. You can find the entry ID in the Web Client in the Metadata tab of the details pane, under Show advanced. This URL can also be obtained by navigating to the document and opening it in the Web Client, then copying the URL from the address bar.
Note: While this syntax can be used on documents of any type, only imaged documents and PDFs will display the document content in the document viewer. Electronic documents will display document metadata only. To open the electronic file portion of an electronic document using a URL, see Opening an Electronic File, below.
When opening a document in the document viewer, you can also use the following options:
- Open to a specific page: https://ServerName/laserfiche/docview.aspx?db=dbName&id=EntryID&page=PageNumber
- Open and perform a search of the document text: https://ServerName/laserfiche/docview.aspx?db=dbName&id=EntryID&find=SearchTerm
- Open in full screen mode: https://ServerName/laserfiche/docview.aspx?db=dbName&id=EntryID&view=fullscreen
- Open a specific version of the document: https://ServerName/laserfiche/docview.aspx?db=dbName&id=EntryID&version=VersionNumber
- Set the document viewer to read only: https://ServerName/laserfiche/docview.aspx?db=dbName&id=EntryID&readonly=true
For information about manually checking out a document for editing using a URL, see Perform Check Out and Check In Operations, below.
Open to a Set of Search Results
You can create a link that will automatically launch a search when the Repository Web Client opens and display the search results. To do so, use the following URL:
- https://ServerName/laserfiche/browse.aspx?db=dbName#?search=SearchSyntax
where dbName is the name of your repository and SearchSyntax is the search syntax of the search you want to perform. Note that if your search syntax string contains characters that are not valid in a URL (which is true of most search syntax strings), you will need to replace them with the appropriate URL encoding.. In most cases, rather than do this manually, you should perform the search in the Web Client, then use the Copy Search URL option to get the full search URL.
If the search has only one result, you can specify that it should open that document or folder automatically, rather than opening the search results. (If there are more than one result, the search results will be opened instead.) To do so, use the following URL:
- https://ServerName/laserfiche/browse.aspx?db=dbName#?search=SearchSyntax&openlfoneresult=true
To open a saved search, use the following URL:
- https://ServerName/laserfiche/browse.aspx?db=dbName#?searchname=SavedSearchName
where SavedSearchName is the name of the saved search. Note that if your saved search name contains characters that are not valid in a URL, you will need to replace them with the appropriate URL encoding.
Open in a View Mode
The Repository Web Client supports responsive view modes, displaying content optimized for the size of the screen or device on which it's being viewed. Using a custom URL, you can specify the view mode that the page will be opened in. This is particularly useful for integrations and when displaying the Web Client in an iframe.
There are several view modes available. Small, medium, and large view modes correspond to the way the Web Client is displayed in browser windows of various sizes. (Large view mode is the default when viewing the Web Client in most browsers.) Phone view mode is optimized for phones, and embedded view mode is optimized for embedding the Web Client in an iframe.
- Small: https://ServerName/laserfiche/browse.aspx?db=dbName#&mode=small
- Medium: https://ServerName/laserfiche/browse.aspx?db=dbName#&mode=medium
- Large: https://ServerName/laserfiche/browse.aspx?db=dbName#&mode=large
- Phone: https://ServerName/laserfiche/browse.aspx?db=dbName#&mode=phone
- Embed: https://ServerName/laserfiche/browse.aspx?db=dbName#&mode=embed
Note that the view mode URL options will only take effect if the link is used when the user is logged out; it will not take effect if used while a user is logged in. Descriptions for the view modes are noted below:
Document Viewer
- Small: Less than 580 px wide
- Medium: Between 580 and 799 px wide
- Large: Between 800 and 1023 px wide
- Regular, Desktop View: 1024 px and larger
Folder Browser
- Small: Less than 620 px wide
- Medium: Between 620 and 799 px wide
View mode options can be combined with other URL options by appending an ampersand and then the option at the end of the URL.
- Example: https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&mode=embed
Open Documents in the Same Tab as the Folder Browser
By default, the Repository Web Client opens documents in the document viewer in a new tab. You can use a URL option to instead force the Web Client to open documents in the same tab as the folder browser. This is particularly useful for embedding the Web Client in an iframe.
- https://ServerName/laserfiche/browse.aspx?db=dbName#?newtab=disabled
where dbName is the name of your repository. Note that this URL option will only take effect if the link is used when the user is logged out; it will not take effect if used while a user is logged in.
- Example: https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&mode=embed&newtab=disabled
Open an Electronic File
You can create a link that will open directly to the electronic file portion of an electronic document. Since electronic files cannot be viewed in the document viewer, there are two ways that users can open these documents. If an electronic file is a Microsoft Office file type (Word document, Excel spreadsheet, PowerPoint slide deck, or Outlook message), you can create a link that will open the document directly using the Office Integration, or you can create a link that will download it. (If you choose to open it directly, the user can then choose whether to open it for editing or for viewing only.) If an electronic file is not a Microsoft Office file type, you can either create a link that will download the document, or, if it is an audio or video file, you can create a link that will stream it directly in the browser.
Microsoft Office Documents
There are two ways to open a Microsoft Office document using a URL: you can open it directly using Office Integration, which will allow you to view and modify the document and its metadata in the Office application and then save the changes directly back to Laserfiche, or you can download it. If you choose to open it in Office Integration, you will be prompted to decide whether you want to open it for editing (which will check it out) or purely for viewing.
- Open with Office Integration: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=OfficePlugin
- Download: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=Export
Other Electronic Document Types
Electronic documents that are not Microsoft Office documents can be either downloaded or, if they are audio or media files, streamed directly in the browser.
- Stream media file (audio and video files only): https://ServerName/laserfiche/browse.aspx?db=dbName&media=EntryID
Open to a Quick Access View
The Repository Web Client provides users easy access to certain categories of documents using quick access views. These include Starred, Documents in Use, Recently Opened Documents, Records Management views, and the Recycle Bin. You can create a URL to link a user directly to a quick access view.
- Starred: https://ServerName/laserfiche/browse.aspx?db=dbName#?view=starred
- Recently Opened Documents: https://ServerName/laserfiche/browse.aspx?db=dbName#?view=recent
- Documents in Use: https://ServerName/laserfiche/browse.aspx?db=dbName#?view=checkout
- Recycle Bin: https://ServerName/laserfiche/browse.aspx?db=dbName#?view=recycle
- Records Management - eligible for cutoff: https://ServerName/laserfiche/browse.aspx?db=dbName#?cutoff
- Records Management - eligible for disposition: https://ServerName/laserfiche/browse.aspx?db=dbName#?disposition
- Records Management - vital records to review: https://ServerName/laserfiche/browse.aspx?db=dbName#?vital
You can create a link that will automatically check the specified document out, or check it back in.
Checking Out a Document
There are three ways to check out a document: you can check out an imaged document if it is under version control, you can manually check out any type of electronic document, or you can use the automatic check out feature of Office Integration to check out a Microsoft Office document type. When you create one of the links below, if a user follows the link, the document will be checked out and opened for them.
- Check out an imaged document under version control: https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&action=checkout
- Manually check out an electronic document: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&EntryID=id&mode=Export-Checkout
- Check out a document using Office Integration: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=checkout-officeplugin
Checking In an Imaged Document
You can create a URL that will automatically check in an imaged document that is checked out. This is useful if you want to prompt a user to save their changes so that they can be seen by other users, and so that the document is available for editing by other users. To do so, use the following URL:
- https://ServerName/laserfiche/browse.aspx?db=dbName#?id=id&action=checkin
You can also use the following check in options:
- Check in as a new version: https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&action=checkin&edoccheckinoption=checkin
- Check in and provide a specific version comment: https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&action=checkin&versioncomment=VersionComment
Note: . Note that if your version comment contains characters that are not valid in a URL, you will need to replace them with the appropriate URL encoding.
- Check in as a new document: https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&action=checkin&edoccheckinoption=newdocument
- Check in as a new member of the link group: https://ServerName/laserfiche/browse.aspx?db=dbName#?id=EntryID&action=checkin&edoccheckinoption=newlink
Checking In an Electronic Document
You can create a URL that will automatically check in an electronic document that is checked out. This is useful if you want to prompt a user to save their changes so that they can be seen by other users, and so that the document is available for editing by other users. To do so, use the following URLs:
- Check in a document that was checked out using Office Integration: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=checkin-officeplugin
- Check in a document that was checked out manually: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=checkin
- Check in as a new version: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=checkin-newversion
- Check in as a new document: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=checkin-newdocument
- Check in and overwrite the existing electronic file (not available for documents under version control): https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=checkin-overwrite
- Check in a document as a new member of a link group: https://ServerName/laserfiche/electronicfile.aspx?db=dbName&id=EntryID&mode=checkin-newlink
Launch Web Scanning
You can create a URL that will automatically launch Laserfiche Scanning. For more information, see Launching Web Scanning with a Custom URL.
