Records Management Administration
Certain administrative configuration is necessary before you can begin creating and managing records. You will need to ensure that your records managers the correct rights to perform records management actions, and you will need to create the relevant records management instructions and definitions (such as retention schedules and cutoff instructions) that will be used to govern records.
Records Management Security
There are several rights that are specific to records management: the Records Management privilege, and several records management-specific entry access rights. In addition, records managers must have all other relevant rights to view record information.
Records Management Privilege
The Records Management privilege allows records managers to create records management definitions such as retention schedules and cutoff instructions in Repository Administration, and perform record actions such as cutoff and final disposition in the repository. This privilege does not bypass other forms of security; users must still have other appropriate rights to view and modify records. (Users without this privilege can still view and modify record contents such as pages and metadata, and view but not modify record properties such as life cycle status, as long as they have sufficient other rights.)
Retention schedules, cutoff instructions, events, cycle definitions, and locations must be created in Repository Administration before they can be applied to record series, record folders, and records.
Records Management Entry Access Rights
Records management operations that are not controlled by the Records Management privilege are controlled through four entry access rights:
  • Set Last Review Date: Set, unset, or modify the review date on a vital record.
  • Close/Reopen Folder : Close and reopen record folders, and file new records into closed record folders.
  • Add/Remove Hold: Add and remove holds on entries.
  • Set Event Time: Set, unset, or modify the event date on a record folder. Set, unset, or modify the alternate retention event date.
Records Management Entry Access Rights and Basic Laserfiche Security
In addition to records management entry access rights, standard Laserfiche security rules still apply. If users are unable to see a record, they will be unable to perform records management actions on that record. Users must have the Browse and Read entry access rights on a record folder or record to perform any records management functions on it.
For more information, see Security.
Records Management Instructions and Definitions
In Repository Administration, you can set up retention schedules, cutoff instructions, events, cycle definitions , and locations that are used to govern records in your repository.
Retention Schedules
Records enter their retention period after they are cutoff. A retention schedule is a collection of rules, usually dictated by compliance regulations, that governs how records are to be stored and for how long.
Retention schedules are created and defined in repository administration and are applied to record series, record folders, or individual records in the repository itself. You must be assigned the Records Management privilege to create, modify, and apply retention schedules.
Metadata retention
When configuring retention schedules, you can select to retain record's metadata information after the record is removed from the Laserfiche repository. This means that the record's images, text, and electronic files will be removed from the repository, but field values, records management state, and other metadata (with the exception of version history) are retained. Metadata is retained by default, and should not be deleted unless there is a valid reason to do so, since it also proves the records were retained correctly even after they are destroyed.
The retention schedule defines the following:
  • How long records must be retained.
  • The order, duration, location, and instructions for interim transfers.
  • The final disposition of the records.
  • The event or events that would trigger an alternate retention schedule, if applicable.
To create a retention schedule
Before creating a retention schedule, first create any locations and events that will be used .
  1. If you are not already in the repository administration section of Laserfiche, open the Repository Web Client and select your user name in the upper right, then select Administration.
  2. Select Records on the left.
  3. Select the Retention Schedules tab.
  4. Click the Add button (The Add button, a dark gray plus sign.).
  5. In the General tab, enter a name and description.
  6. In the Instructions tab, specify the initial retention period.
  7. Click Add if you want to insert transfer instructions as part of the retention schedule. Fill in the following:
    • Select a location for the transfer in the Location option of the Transfers table. If the transfer is within the current file area, select Current file area. (Locations other than Current file area must have already been defined in the repository. See Locations for more information.)
    • In the Retain (months) option, select the number of months the record should be kept at this location.
    • In the Action option, select Retain all data to keep all information when the record is stored at this location, Retain metadata to keep the metadata about the document but destroy the pages or electronic file, or Destroy records to destroy the entire record.
  8. In Final disposition, select the final disposition action for the retention schedule.
  9. If you selected Accession as the final disposition action, choose the Archival Location. Note that you will not be able to select the current filing system as an archival location, because accession means you are transferring records management responsibility and authority for the records. (Locations must have already been defined in the repository. See Locations for more information.)
  10. Select or clear the option to Retain metadata after performing the final disposition action. In general, we recommend that you retain your record metadata unless your compliance regulations require otherwise
  11. Click OK to close the New Retention Schedule dialog box and save the retention schedule.
Cutoff Instructions
A cutoff instruction defines when a record folder or record will become eligible for cutoff, and therefore when its retention schedule will begin. Each type of cutoff instruction provides a different way of calculating cutoff eligibility , offering you a more flexible solution to managing your records.
Laserfiche offers the following types of cutoff instructions:
  • ClosedTime
  • Time-based cutoff instructions cause records to become eligible for cutoff based on both a cycle definition (e.g., monthly or yearly) and the filing date of the record folder. The record becomes eligible for cutoff at the start of the next cycle following the record folder's filing date. Cutoff eligibility for time cutoff is calculated based on cycles and not on an absolute time interval. If you want to use an absolute time interval, you can do so with the Interval cutoff instruction.
    Time cutoff allows record series or record folders from a specific time period to become eligible for cutoff at the same time so that records managers can group and cutoff all eligible entries at the same time. By default, the filing date is the creation date of the record folder, but it can be manually set to a different date (including future dates).
  • ClosedEvent
  • Event-based cutoff instructions cause records to become eligible for cutoff based on the occurrence of one or more events. When an event occurs, a user with the Set Event Time entry access right can set the event date.
    If a cutoff instruction only contains one event, the record folder will become eligible based on that event date. If a cutoff instruction contains multiple events, the administrator who configured the cutoff instruction can determine how the multiple events are handled: if Cutoff eligibility requires all events is selected, records are eligible when all event dates have been set and the final event date chronologically has passed (cutoff is based on the final event date); if Cutoff eligibility requires any events is selected, the record is eligible when at least one event date has been set and has passed (cutoff is based on the first event date set).
    Note: If a record folder is uncutoff, the date for the event that caused the record to be eligible for cutoff (the final event date if all events were required, or the first if any event was required) will be unset.
    Note: An event date can be set to a date in the future. This will close the record folder immediately, but the record folder will not become eligible for cutoff until the event date.
  • ClosedTime+Event
  • Time+Event-based cutoff instructions combine the properties of Time and Event cutoff instructions. Records affected by a Time+Event cutoff instruction become eligible for cutoff based both the occurrence of one or more events and the cycle definition (e.g., monthly or yearly)
    Eligibility for cutoff is based on both the cycle time and the events set. If the cutoff instruction is set to require all events, the relevant event is the final event by date once all dates have been set; if the cutoff instruction requires any event, the relevant event is the first event by date. Once the event date passes (whether first or final), the record will be eligible for cutoff on the first day of the next time cycle.
  • ClosedInterval
  • Interval-based cutoff instructions cause records to become eligible for cutoff based on both the passing of a certain number (interval) of months and the filing date of the record folder.
    Cutoff eligibility occurs at the end of a specific interval of months. Interval cutoff instructions are triggered on individual record folders and require the passing of an exact number of months. If you want to use a time interval that is dependent on specific time cycles, you can do so with the Time cutoff instruction (where cutoff eligibility occurs on the first day of the next cycle period). Time cutoff allows record series or record folders from a specific time period to become eligible for cutoff at the same time, allowing the records manager to group and cutoff all eligible entries at the same time.
  • ClosedInterval+Event
  • Interval+Event-based cutoff instructions combine the properties of Interval and Event cutoff instructions. Records affected by an Interval+Event cutoff instruction become eligible for cutoff based both the occurrence of one or more events and the passing of a certain number of months (interval).
    The record becomes eligible for cutoff based on both the critical event and the interval. If the cutoff instruction is set to require all events, the critical event is the final event by date; if the cutoff instruction requires any event, the critical event is the first event. After the critical event date occurs, the specified interval of months begins counting down. The record will be eligible for cutoff when the interval ends.
  • ClosedSuperseded
  • Superseded-based cutoff instructions cause records to become eligible for cutoff based on whether the record has been superseded by another entry.
    Linking the record to another entry using the "Superseded by" document relationship will trigger the record's cutoff. For this instruction type, cutoff happens automatically, and does not require a records manager to perform cutoff. (If the record is set with the "Supersedes" document relationship, which is the complementary half of the same link, it will not trigger cutoff for the record on the "Supersedes" side of the relationship.)
    Superseded cutoff is a record-specific cutoff instruction. Simply applying the correct document relationship will automatically trigger cutoff, regardless of what else is happening in the record folder.
  • ClosedDisposition Action
  • Disposition action-based cutoff instructions cause records to become eligible for cutoff based on two factors: whether a record has a particular type of document relationship to another record, and whether a particular records management action has been performed on the document that the record is linked to. You can specify any document relationship to use with this disposition type. Cutoff can be triggered based on the linked document either being transferred or entering final disposition.
    Disposition Action cutoff is a record-specific cutoff instruction. Cutoff will happen as soon as the specified disposition action is performed on the linked record. Cutoff is automatically triggered once the specified records management action is performed on the document the record is linked to, regardless of what else is happening in the record folder.
To create cutoff instructions
  1. If you are not already in the repository administration section of Laserfiche, click the grid icon (The grid button, a three by three grid of white squares.) in the upper right corner and select Repository Administration.
  3. Select the Cutoff Instructions tab.
  4. Click the Add (The Add button, a dark gray plus sign.) button.
  5. Enter a Name and optional Description.
  6. In the Type option, select the desired cutoff instruction. Depending on the cutoff type selected:
    • ClosedTime
    • Select the desired cycle from the Cycle drop-down menu. (You can create additional cycle definitions if you want to use one that isn't already in the list. See Cycle Definitions for more information.)
    • ClosedEvent
    • Select an existing event from the drop-down menu, or click Create new event. Repeat for as many events as you want to include. For cutoff instructions with multiple events, select Cutoff eligibility requires any event to allow cutoff as soon as one event date is set, or Cutoff eligibility requires all events to allow cutoff only after all event dates have been set. To remove an event, select it and click Remove
    • ClosedTime+Event
    • Select the desired cycle from the Cycle drop-down menu. (You can create additional cycle definitions if you want to use one that isn't already in the list. See Cycle Definitions for more information.) In the Events section, click Create new event and type the name of an event or select one from the drop-down menu. Repeat for as many events as you want to include. For cutoff instructions with multiple events, select Cutoff eligibility requires any event to allow cutoff as soon as one event date is set, or Cutoff eligibility requires all events to allow cutoff only after all event dates have been set. To remove an event, select it and click Remove
    • ClosedInterval
    • Type the length, in months, of the interval you want to configure in the Interval field.
    • Type the length, in months, of the interval you want to configure in the Interval field. In the Events section, click Add and type the name of an event or select one from the drop-down menu. Repeat for as many events as you want to include. For cutoff instructions with multiple events, select Cutoff eligibility requires any event to allow cutoff as soon as one event date is set, or Cutoff eligibility requires all events to allow cutoff only after all event dates have been set. To remove an event, select it and click Remove
    • ClosedSuperseded
    • No further configuration is necessary.
    • From the Document Relationship drop-down menu, select the document relationship type that will satisfy the cutoff instruction. Next, in the Linked action drop-down menu, select which action performed on the linked document will trigger the record's cutoff eligibility. If you select Transfer from the Linked Document Action drop-down menu, specify the transfer location that will satisfy the cutoff instruction from the Location drop-down menu. (Locations must have already been defined in the repository. See Locations for more information.)
  7. Click OK to close the dialog box and create the new cutoff instruction.
Events
An event is an occurrence that causes records with an Event, Time+Event, or Interval+Event cutoff instruction to be cut off, or that may trigger an alternate retention schedule.
To create an event
Tip: Events can also be created while creating cutoff instructions.
  3. Select the Record Properties tab.
  5. In the Name option, specify a name for this event.
  6. Optional: In the Description option, type a description for the event.
  7. Click OK to add the event.
Cycle Definitions
Cycle definitions are used by Time and Time+Event cutoff instructions to determine cutoff eligibility, as well as to determine vital record review cycles. Laserfiche includes nine predefined cycle definitions, which can be modified, and allows you to create new definitions. Each cycle definition is composed of the following properties:
  • Code
  • Description
  • Type of cycle
  • Individual periods that determine the cycle
Types of cycle definitions
There are two types of cycle definitions:
  • Monthly cycle definitions can contain anywhere from a single month to 12 months. The month specified in a monthly cycle definition indicates the end of the period. Any applicable records management actions that depend on the cycle become eligible at the start of the following period.
    Example: A monthly cycle definition with one period set to December creates a yearly cycle where records would become eligible for cutoff and vital records would be due for review on January 1. Another monthly cycle definition with six periods (i.e., February, April, June, August, October, December) creates a bimonthly cycle where records would become eligible for cutoff on the first day of the month following the end of the period (e.g., March 1 for the February period).
  • Daily cycle definitions can contain anything from a single day to seven days. Any applicable records management actions that depend on the cycle become eligible at the start of the specified day.
    Example: A daily cycle definition that has one period set to Wednesday creates a weekly cycle where records would become eligible for cutoff on Wednesday.
Note: Monthly cycle definitions and daily cycle definitions behave differently. A monthly cycle period definition indicates the end of the period, with records management actions becoming eligible on the first day of the next month. A daily cycle period definition indicates the day of the week on which records management actions become eligible.
To create a cycle definition
  4. Under Review Cycles, click the Add (The Add button, a dark gray plus sign.) button.
  5. In the Code option, specify a cycle definition code to identify the cycle.
  6. Optional: In the Description option, type a description for the cycle definition.
  7. In the Cycle definition option, select Set cycle by and then specify the month or months.
  8. Click OK to add the cycle definition.
Locations
Before you can select a location in a retention schedule, you must first define the physical location that your records will be transferred or accessioned to.
To create a location
  4. In the Locations section, click the Add (The Add button, a dark gray plus sign.) button.
  5. In the Name option, specify a name for the location.
  6. Optional: In the Description option, type a description for the location.
  7. Optional: In the Contact information option, add any contact information that you want to include for this location. You can provide a fax number, address, name, phone number and email for up to two contacts.
  8. Click OK to add the event.
Holds
Holds prevent modification to documents and halt their records management life cycles.
To view holds
  3. Select the Holds tab.
  4. The list of all existing hold reasons and their due dates (if any) will be displayed.
  5. To view the entries assigned a particular hold, select the hold name. In the Edit Hold dialog box, select View entries.
To delete a hold
  4. The list of all existing hold reasons and their due dates (if any) will be displayed. Select the hold that you want to remove and then select the Delete button. This will delete the hold and remove it from all entries to which it was assigned.
