Adding Fields to a Form
Forms in a business process help to capture information from users. You can access the form designer from the process designer by either creating a new form or editing an existing form.
Once in the form designer, use the Layout page to configure fields on a form. To save changes, click Save . To preview the form, click Preview
Click, or drag and drop, one of the following fields or elements to add it to a form:
- Single Line: For text data that doesn't take up more than one line.
- Multi-line: For text data that takes up more than one line.
- Checkbox, Drop-down, or Radio Button: For data that can take on one or more of a finite set of values.
- Number: For numerical data. More restrictions than a single line field.
- Currency
- Date, Time
- File Upload: Let users attach files to a form.
- File Set
- Address
- Rich Text
- Custom HTML: For including custom HTML like IFrames or images.
- Signature
- Geolocation: Input longitude and latitude GPS coordinates. Can also attempt to automatically collect location via the browser IP address.
- Page Break: Break a long form up into multiple pages or tabs.
Note: This is called Pagination in the forms designer, available in the right pane form settings on the Basic tab.
- Section: Does not collect data, but allows parts of form to be collapsed. Also helps visually distinguish different parts of form.
- Collection: Allows repeating sets of the same types of fields. Can be set to have fixed or variable number of sets.
- Table
In the form designer, select the field and the options will be displayed in the right pane. To edit a field in the classic form designer, select the field and then click Edit.
Fields can be configured with many options. They can be read-only, have a default value, and have a custom CSS class, among other things. Explore the types of fields above to see what options they come with.
Editing the Form's Properties
In the Form Designer:
To rename the form, click the pencil icon next to the name in the upper left corner of the canvas area.
To change the form properties:
- Click on the form in the canvas near the title.
- The details pane will appear on the right.
- On the Basic tab, edit the Form Title and Description. Click the variable button
to use variables in your description.
- To change the form name, click the pencil icon near the form name in the toolbar.
- To edit form settings, click on the form near the title in the canvas.
- On the Basics tab you can:
- Edit the Form Title and Description.
- Under Responsive Layout, if you have created a custom layout that you wish to remain unchanged when viewed on a mobile or other small screen device, check the option to Disable automatic layout adjustment for small screens. Otherwise, the form will be automatically optimized for use on mobile devices.
- Set the Maximum Width, in pixels, that main form will cover in the browser.
- Set the Saved Page Orientationto either Portrait or Landscape. This controls the layout of the document created when saving a submitted form.
- Under Pagination, select Enable Pagination to show the form on multiple pages.
- Select Show submission actions on every page to display the action buttons you define on every page of the form. By default, actions are only displayed on the last page of a multi-page form.
- Select Enforce validation on page progression to automatically validate data entered by the user before allowing them to continue to the next page. If the selected pagination style allows a user to skip a page, validation will not be enforced. To fully enforce validation, use the Progress bar pagination style.
- Select Add page breaks to saved forms to include page breaks in saved forms.
- Under Pagination Style, select the type of page navigation to use. Select Include previous/next buttons if desired.
- Under Pages, add, rearrange, or remove the number of pages desired, and configure the Page Name, Previous Button text, or Next Button text.
- Under Label Alignment, set where
- If Left or Right alignment is selected above, select from a small, medium, or large Label Width space.
- On the Rules tab you can view and create Field Rules, Lookup Rules, and configure Custom Error Messages.
- All changes will be applied automatically to the canvas.
Searching for Form Fields
You can search across all pages of a form for specific fields. This may help in locating a field on a long form or a form with many pages.
To search for a field:
- Click the magnifying glass in the upper right toolbar.
- The right pane will display a search bar and any results once a search is completed. Enter a value to search on. You can search by field type, description, variable, or ID, and can use a partial value to return multiple items.
- The results will be displayed as descriptive cards, containing details about the field.
- Click on the card to highlight the field on the form. Click on the card's field type (in blue) to highlight the field on the form and open it's settings in the right pane. If a field is associated with rules or custom error messages, you can click the rule/error count to be taken directly to the rules tab for the field.
- Click the form's title, then click Edit.
- Edit the title and description. Click the variable button
- Optional: Hide the form's title by clearing the Show form title checkbox.
- When you are finished, click Done.
In the classic form designer, click the Form Settings button on the top right of the forms page to do the following:
- Name: Rename the form.
- Responsive layout: Enable or disable a responsive layout.
- Maximum width: Adjust the width of the entire form.
- Saved Page Orientation: Set the form to portrait or landscape orientation. This option only applies when printing, downloading, and saving the form. This does not affect how the form is displayed in the browser.
- Alignment: Align the field labels to the left, right, or top of the fields.
- Width: Adjust the width of the field labels that have been aligned to the left or right.
Important: Custom CSS may interfere with a responsive design, so we recommend previewing responsive forms that have custom CSS styling to ensure the form re-sizes as desired. If your custom CSS styling is more important than having a responsive form, you may choose to disable responsiveness.
Copying and Deleting a Form
- Click the Copy button
to copy a form, including all of the fields with their corresponding variables. The new form will be in the same format (Classic or Form Designer) as the original.
- Click the Delete button
to delete a form.
Converting a Classic Form to the Designer
To convert a form created in the classic designer to the new format, click the Convert form button on the toolbar, provide a new name for the form, and click Convert.
Note: Any custom CSS or JavaScript will not be included. Any JavaScript used on the classic form will have to be re-written to use the LFForm object.
Related Topics
