List of Variables
Variables store information from form fields and business processes. The variables that you can use in a form vary depend on the situation. For example, previous task variables are not available when configuring the On Event Completion page, because the message shows before any tasks run.
Process
Variable Syntax Description
Business Process ID {/dataset/_bp_process_id} The ID of the forms process.
Business Process Name {/dataset/_bp_process_name} The name of the forms process.
Process Time Zone {/dataset/_process_time_zone} The time zone of the forms process.
Process End Date {/dataset/_process_end_date} The date the form or survey is set to expire and become unavailable.
Current Step Name {/_current_step_name} The name of the currently running step in the process.
Instance
ID {/dataset/_instance_id} The instance ID.
Initiator email {/dataset/_initiator_email} The email address of the user who started the process instance.
Initiator name {/dataset/_initiator_displayname} The name of the user who started the process instance (e.g., John Smith).
Initiator username {/dataset/_initiator} The user name of the user who started the process instance (e.g., jsmith).
Start Date {/dataset/_initiated_date} The date when the process instance started.
Start Time {/dataset/_initiated_time} The time when the process instance started.
Previous Submission
These variables refer to the previous user or service task that submitted a form.
Action {/dataset/_action} The action performed by the user or task that last submitted a form (e.g., approve or reject).
Comment {/dataset/_comment} The comments left by the user or task who submitted the form.
Completion date {/dataset/_submission_date} The date when the form was submitted.
Completion time {/dataset/_submission_time} The time when the form was submitted.
Participant email {/dataset/_submitter_email} The email address of the user who submitted the form.
Participant name {/dataset/_submitter_displayname} The name of the user who submitted the form.
Participant username {/dataset/_submitter} The user name of the user who that submitted the form.
Submission ID {/dataset/_submission_id} The ID of the submission.
Submission IP Address {/dataset/_submission_ip_address} The IP address of the computer from which the last form was submitted.
Previous User Submission
Unlike the Previous Submission Variables, these variables refer only to the previous user task.
Action {/dataset/_fs_action} The action performed by the user who last submitted a form (e.g., approve or reject).
Comment {/dataset/_fs_comment} The comments left by the user who submitted the form.
Completion date {/dataset/_fs_submission_date} The date when the form was submitted.
Completion time {/dataset/_fs_submission_time} The time when the form was submitted.
Participant email {/dataset/_fs_submitter_email} The email address of the user who submitted the form.
Participant name {/dataset/_fs_submitter_displayname} The name of the user who submitted the form participant (e.g., John Smith).
Participant username {/dataset/_fs_submitter} The user name of the user who submitted the form (e.g., jsmith).
Submission ID {/dataset/_fs_submission_id} The ID of the submission.
Submission IP Address {/dataset/_fs_submission_ip_address} The IP address of the computer from which the last form was submitted.
Previously Saved Form
These variables refer to the repository entry created by a Save To Repository task, and refer to the last saved data within the repository.
ID {/dataset/_saved_form_id} The entry ID of the saved form.
Path {/dataset/_saved_form_path} The repository path to the entry.
Attachment List {/dataset/_saved_form_attach_list} The list of attachments as a comma delimited list of IDs.
Name {/dataset/_saved_form_name} The name of the entry as specified when the form was saved.
Link {/dataset/_saved_form_link} The URL of the entry.
Folder ID {/dataset/_saved_form_folder_id} The entry ID of the folder where the form was saved.
Folder Link {/dataset/_saved_form_folder_link} The URL of the folder entry.
Folder Name {/dataset/_saved_form_folder_name} The name of the folder.
Folder Path {/dataset/_saved_form_folder_path} The path of the folder.
Folder Attachment List {/dataset/_saved_form_folder_attach_list} The list of IDs for the parent folders for the files that were attached to the form.
User Task(s)
Assigned to {/dataset/_task_assigned_to[@_step_id=n]} where n is the step ID. The assignee of the user task.
Due date {/dataset/_task_due_date[@_step_id=n]} where n is the step ID. The due date for the task.
Priority {/dataset/_task_priority[@_step_id=n]} where n is the step ID. The priority of the user task.
Resume ID {/dataset/_task_resume_id[@_step_id=n]} where n is the step ID. The resume ID is a unique identifier for a user task. It can be used to construct task link. The resume ID will be available once a user task is generated. The resume ID will not change after a task is reassigned, and will be the latest created resume ID if there are multiple user task instances created for the same process instance.
Start date {/dataset/_task_date[@_step_id=n]} where n is the step ID. The date the user task was started.
Start time {/dataset/_task_time[@_step_id=n]} where n is the step ID. The time the user task was started.
Task Link {/dataset/_task_link[@_step_id=n]} where n is the step ID. A URL to a user task, which will navigate the user to the user task in a browser.
