Solution Templates
The Solution Templates feature pre-built processes and forms tailored for a range of business needs. You can use these as templates for your own processes.
Requirements
Security Requirements
Product | Minimum Required Security |
Business Processes |
One of the following security roles is necessary to create new processes:
Repository |
To work with the contents of a Laserfiche repository, a user account needs a variety of Laserfiche privileges and access rights. Some processes in the library involve tasks that carry out repository actions. The permissions that these tasks require are as follows.
To access the Solution Templates
- In the top navigation bar, click Design.
- In the Designer dialog box, click
Solution Templates. Solution templates can also be accessed from marketplace.laserfiche.com. Learn more about the Solution Marketplace.
- Under Solution Templates, filter by the desired category or industry.
- Click on a process to view additional details about a process.
- In the process details page, click Download Files to download the Laserfiche briefcase files necessary for the process.
- Click Import Process to create a new process using the pre-built elements as a basis. Work through the wizard to verify or change users, forms, workflows, rules, repositories, and settings associated with the imported process. You will be able to specify a new name for the process in a dialog. After clicking Upload, you will be taken to the process designer, where you can modify the process for your own usage.
Note: Import Process creates a new business process with pre-configured activities and forms. For many areas that require your specific organization's information, the process template fills in initial default values. You must review and modify these initial settings before running the process.
Configuration
Process templates will include one or more of the following potential areas of configuration.
Note: Please view the annotations on downloaded process diagrams for information on process-specific details that may require additional configuration.
Download and import the Laserfiche briefcases.
The details page for each process template will include supplemental files for download required for the process to run. Each process will include a Laserfiche briefcase file that includes template definitions that you can import into your Laserfiche repository. These supplemental files require additional configuration.
Laserfiche briefcase files are used outside of business processes.
- Use the Documents application to import the briefcase into your document repository.
- Configure the repository profile for any Save to Repository service tasks
- View the predesigned forms and update form text and fields.
View any email service tasks and modify the preset values to match your organization.
- Update the Send to and From options to reflect your specific process. By default, the Send to option is set to the process initiator.
- Update the email text as desired.
- View user tasks and set the user task assignments.
- View timer events and review timer settings.
- Create and configure teams if necessary.
Further Help and Feedback
If you have questions, suggestions, or feedback, please post on the Laserfiche Answers Solution Templates group (https://answers.laserfiche.com/groups/36/Business-Process-Library).
