Quick Fields Agent Administration Console Interface and Navigation
The Quick Fields Agent Administration Console is a snap-in for the Microsoft Management Console, which determines its appearance.
The left pane, known as the ClosedConsole Tree, lists all available items.
Quick Fields Agent Administration Console Tree
The center pane, the ClosedResults Pane, updates to show information related to whichever item is selected in the Console Tree.
This pane shows information related to the item selected in the Console Tree
Right‑clicking any item in either pane opens a context menu, and the same options also appear in the ClosedActions Pane on the right. These actions allow you to view properties, add or remove columns, and more.
Actions Pane
For additional details on navigating the interface, consult the Microsoft Management Console help files, available from the Help menu alongside the Quick Fields Agent documentation.
Note: To see the most recent information, you may need to right-click in a pane and select Refresh.
