The Quick Fields Agent Administration Console
Note: Laserfiche 12 will introduce user interface updates to the Laserfiche Quick Fields Agent Administration Console. However, it will not include the Web Administration Console, as this component has been deprecated in the Spring release. For documentation on the Web Administration Console for Quick Fields Agent, refer to the Laserfiche 11 help files.
The Quick Fields Agent Administration Console is used to create schedules for Quick Fields sessions that the Quick Fields Agent Service will run automatically, and view the history of sessions that have already run. The Quick Fields Agent Administration Console can be installed on multiple computers, which is useful if, for example, the Quick Fields Agent Service is installed in the server room and you want to manage schedules from your desk. To connect to the Quick Fields Agent Service from an administration console on another machine, you must enable Remote Access.
