Get-LocalNode
Synopsis
Gets a summary of all of a node's settings.
Syntax
Get-LocalNode
Detailed Description
The Get-LocalNode function returns an object that contains all the node's settings that are accessible from the LfDccLocalNodeAdmin module.
Inputs
None
Outputs
Laserfiche.DistributedComputingCluster.PowerShellModules.LfDccLocalNodeAdmin.Data.LocalNode
An object that contains all the settings of the node that are accessible from the LfDccLocalNodeAdmin module.
Examples
Example 1
This command gets all of the node's settings.
PS C:\> Get-LocalNode
Ports : MetaData: 8108
BufferedCommunication: 8107
SecuritySettings : AuthenticationMode: None
EncryptionMode: None
AuthorizationRoles : Admin: {Administrators}
ReadOnly: {Administrators, Everyone}
Client: {Administrators, Everyone}
Machine: {Administrators, Everyone}
MaxConcurrentTaskCountPolicy : Automatic (0)
IsScheduler : False
SchedulerHostName : v-load-2cpu-2.laserfiche.com
SchedulerMetaDataPort : 8108
