Reset-LocalNode
Synopsis
Resets the settings of the node.
Syntax
Reset-LocalNode
Detailed Description
The Reset-LocalNode function sets the port, max concurrent task policy, authentication, encryption, and authorization settings back to their defaults.
Inputs
None
Outputs
None
Examples
Example 1
This command resets all the settings of the node.
PS C:\> Reset-LocalNode
Related Links
Get-LocalNode
