Get-LocalNodeServicePort
Synopsis
Gets the port numbers that the node listens on.
Syntax
Detailed Description
The Laserfiche Distributed Computing Cluster Service uses two ports to communicate with other applications. A node is identified by its host name and by its metadata port. The node uses this port to advertise its capabilities and the settings required to establish a secure connection. The node uses the buffered port to securely exchange data with other applications.
The Get-LocalNodeServicePort function returns an object that contains the port numbers that the node uses.
Inputs
None
Outputs
Laserfiche.DistributedComputingCluster.PowerShellModules.LfDccLocalNodeAdmin.Data.LocalNodePorts
Get-LocalNodeServicePort returns an object that contains a property for each port number that the node uses.
Examples
This example gets the port numbers that the node listens on.
PS C:\> Get-LocalNodeServicePort
	MetaData                   BufferedCommunication
	8108                                    8107
Related Links
Reset-LocalNodeServicePort
Set-LocalNodeServicePort
