Reset-LocalNodeServicePort
Synopsis
Resets the port numbers that the node listens on.
Syntax
Detailed Description
The Laserfiche Distributed Computing Cluster Service uses two ports to communicate with other applications. A node is identified by its host name and by its metadata port. The node uses this port to advertise its capabilities and the settings required to establish a secure connection. The node uses the buffered port to securely exchange data with other applications.
The Reset-LocalNodeServicePort command sets the ports that the node uses to the defaults. By default, the node uses port 8108 for metadata communication and 8107 for buffered communication.
Inputs
None
Outputs
None
Examples
Example 1
This command resets the port numbers that the node listens on.
PS C:\> Reset-LocalNodeServicePort
