Remove-DomainUserFromLocalNodeAuthorizationGroup
Synopsis
Removes a user from a node's authorization group.
Syntax
Remove-DomainUserFromLocalNodeAuthorizationGroup [-DomainUserName] <String[]> [-Admin <SwitchParameter>] [-ReadOnly <SwitchParameter>] [-Client <SwitchParameter>] [-Machine <SwitchParameter>]
Detailed Description
The Remove-DomainUserFromLocalNodeAuthorizationGroup function removes a Windows domain user or group from one or more Distributed Computing Cluster authorization groups. Removing a user from an authorization group prevents that user from accessing the functionality available to the group.
Authorization in Laserfiche Distributed Computing Cluster
Laserfiche Distributed Computing Cluster supports authorization to restrict the operations performed by different users.
A Scheduler has four authorization groups (or roles) that Windows users can be assigned to.
- Admin: Users in the Admin authorization group can view administrative information and make changes to the cluster.
- ReadOnly: Users in the ReadOnly authorization group can view administrative information on a cluster, but cannot make changes.
- Client: Users in the Client authorization group can run jobs on a cluster.
- Machine: Users in the Machine authorization group can start operations that are meant to be started by other nodes in the cluster. A node's Machine authorization group should contain all the service users that the other nodes in the cluster run as.
Workers only use the Machine role.
Note: Authorization is only enforced if the node's AuthenticationMode is set to Windows.
Parameters
-DomainUserName <String[]> The domain username of the user or group that will be added to the authorization group (e.g., "LASERFICHE\John.Doe"). Required? true Position? 1 Default value Accept pipeline input? true (ByValue) Accept wildcard characters? false -Admin <SwitchParameter> Specifies that the user or group should be removed from the Admin authorization group. Required? false Position? named Default value Accept pipeline input? false Accept wildcard characters? false -ReadOnly <SwitchParameter> Specifies that the user or group should be removed from the ReadOnly authorization group. Required? false Position? named Default value Accept pipeline input? false Accept wildcard characters? false -Client <SwitchParameter> Specifies that the user or group should be removed from the Client authorization group. Required? false Position? named Default value Accept pipeline input? false Accept wildcard characters? false -Machine <SwitchParameter> Specifies that the user or group should be removed from the Machine authorization group. Required? false Position? named Default value Accept pipeline input? false Accept wildcard characters? false
Inputs
System.String
You can pipe user names of domain users as strings to Remove-DomainUserFromLocalNodeAuthorizationGroup.
Outputs
None
Examples
Example 1
This command removes the user, John.Doe, of the Laserfiche domain from the Admin group.
PS C:\> Remove-DomainUserfromLocalNodeAuthorizationGroup -DomainUserName "LASERFICHE\John.Doe" -Admin
Related Links
Add-DomainUserToLocalNodeAuthorizationGroup
