Reset-LocalNodeAuthorizationGroup
Synopsis
Resets a node's authorization groups.
Syntax
Detailed Description
The Reset-LocalNodeAuthorizationGroup command resets a node's authorization groups to their defaults.
Authorization in Laserfiche Distributed Computing Cluster
Laserfiche Distributed Computing Cluster supports authorization to restrict the operations that can be done by different users.
A Scheduler has four authorization groups (or roles) that Windows users can be assigned to.
  • Admin: Users in the Admin authorization group can view administrative information and make changes to the cluster.
  • ReadOnly: Users in the ReadOnly authorization group can view administrative information on a cluster, but cannot make changes.
  • Client: Users in the Client authorization group can run jobs on a cluster.
  • Machine: Users in the Machine authorization group can start operations that are meant to be started by other nodes in the cluster. A node's Machine authorization group should contain all the service users that the other nodes in the cluster run as.
Workers only use the Machine role.
Note: Authorization is only enforced if the node's AuthenticationMode is set to Windows.
Inputs
None
Outputs
None
Examples
Example 1
This command resets the node's authorization groups.
PS C:\> Reset-LocalNodeAuthorizationGroup
Related Links
Add-DomainUserToLocalNodeAuthorizationGroup
Remove-DomainUserFromLocalNodeAuthorizationGroup
Get-LocalNodeAuthorizationGroup
