Document Viewer
The document viewer allows you to view the pages, metadata, annotations, and other information about documents with image pages, including PDFs. You can also open Microsoft Word, Excel, or PowerPoint documents for viewing and editing, or stream video and audio files. (Other types of documents will be downloaded for opening in their native application by default.)
On the left, you can quickly scan through a document's pages using the thumbnails. To view a page, select it and it will display in the center. On the right, you can view additional information (called metadata) about the selected document or folder. The toolbar at the top allows you to perform actions such as zooming in or out, adding annotations, switching to full screen mode, or saving changes. Above that, the search bar allows you to quickly search within this document.
For more information, see Viewing Documents and Folders and Working with Document Contents.
Free Training:Using the Document Viewer in Laserfiche 12 eLearning course in Aspire.
