Project Explorer Pane
The Script Editor's ClosedProject Explorer Pane appears on the left-most edge of the Script Editor and contains three folders by default.
Tip: If the Project Explorer Pane is closed, you can open the pane by selecting View from the main menu and selecting Project Explorer. Alternatively, use the keyboard shortcut CTRL+SHIFT+P.
  • References: Contains a list of referenced libraries.
  • Shared Scripts: Contains scripts that are available to all activities in the current workflow definition. To add a script or folder to this folder, right-click the folder, point to Add, and select Workflow Script or Folder.
  • The third folder is named to match the Activity Name. To add a script or folder to this folder, right-click the folder, point to Add, and select Workflow Script or Folder.
Tip: Right-click the project node (root node) and select Build to compile the project.
