Script Editor
The Script and SDK Script activities contain a Script Editor that lets you write VB.NET and C# scripts. The editor is color-coded, includes an autocompletion feature, and lets you check for syntax errors.
Script Editor Panes
The Script Editor has several panes to help you organize and write your scripts.
To configure the pane layout to suit your needs
  • To show or hide a pane, select View from the main menu and select a pane to show it or clear a pane to hide it.
  • To change the pane layout, drag and drop panes much like you would in the Workflow Designer. Learn more about configuring Workflow Designer panes.
  • To restore the default pane layout, select View from the main menu and select Restore the Default Layout.
For more information about scripting, see
